Fire System Plumbing? #912388
01/24/11 01:34 AM
01/24/11 01:34 AM
Out West
408strokerdart Offline OP
Out West
I am installing a fire system for driver safety only. I might add another bottle at a later date for extinguishing a under hood fire.
My question is, what is the best place to locate the discharge nozzles? The system came with two nozzles. I'm thinking under the dash bar pointed up at the driver for one of them, but where to mount the other? Maybe pointed down toward the feet? It is a Firebottle brand, FE-36 unit.
Re: Fire System Plumbing? [Re: 408strokerdart] #912389
01/24/11 02:08 AM
01/24/11 02:08 AM
iowa
wesw Offline
wesw  Offline
iowa
look in the rule book. it will tell you where to mount them. on my car one is mounted on the firewall pointing down at the drivers side and the other one is on the other side pointing at the motor. the newer systems have it plumbed back to the kill switch to a valve to shut the car off also.
598 ci predator
Re: Fire System Plumbing? [Re: wesw] #912390
01/24/11 12:28 PM
01/24/11 12:28 PM
springfield,il
O
orangeduster Offline
O
springfield,il
one in the middle of each side of the motor and one under the dash in between the leg of the driver my
Re: Fire System Plumbing? [Re: 408strokerdart] #912391
01/24/11 12:35 PM
01/24/11 12:35 PM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
I put them one at the driver's feet, pointed back towards the driver, then two in the engine bay. I would contact Firebottle and get one more nozzle, and be done with it.
Re: Fire System Plumbing? [Re: Ben Holt] #912392
01/24/11 01:34 PM
01/24/11 01:34 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
My TS car had 4 nozzles. One at your feet, Engine side of firewall had one on each side of motor, and one in front of motor by fuel cell
Re: Fire System Plumbing? [Re: MegaDart] #912393
01/24/11 03:16 PM
01/24/11 03:16 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
x2
Re: Fire System Plumbing? [Re: 408strokerdart] #912394
01/24/11 03:36 PM
01/24/11 03:36 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I have one I need to put in too....I want to mount the bottle in the trunk though (street car)...so I need to figure out how to run a cable back to it the full length of the car.
