collateral damage from points staying closed.
#912315
01/24/11 12:25 AM
01/24/11 12:25 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang... I was out and about in the Daytona yesterday and ran into a situation where I barely made it home. Turned out the points weren't opening on the distributor due to the part of the points that touches the cam was worn down. Is there any chance of collateral damage from points staying closed for the duration. It took me about 5 minutes through traffic to get home. Does the points being close cause the coil to get saturated with voltage and possibly get damaged? How about the ballast resistor being on the primary circuit?
Thanks in advance.. Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: collateral damage from points staying closed.
[Re: DAYCLONA]
#912317
01/24/11 02:31 AM
01/24/11 02:31 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Should be no problem. toss in a fresh set of points, gap them at .018 . Remember to lube the rubbing block with a tiny bit of lube... the lube used to come with points... Di-lectric grease should work.. They should last 10k miles with no maintenance ...
[Re: DAYCLONA]
#912318
01/24/11 09:41 AM
01/24/11 09:41 AM
Challenger 1
Cincinnati, Ohio
I wouldn't worry about any damage from a dimished point gap,....you know how nice the Petronix is on the 500,....I mentioned earlier to ditch the points in the Daytona,...guess I put the "kabosh" on ya!
...ditch the points, ballast and coil, put a Petronix Ignitor II and Flame Thrower II coil in the Tona
Yea, why would you run points??? I've installed them in every vehicle I've ever touched with points.
[Re: Challenger 1]
#912319
01/24/11 10:05 AM
01/24/11 10:05 AM
hemi68charger
Houston, Tx
I knew I couldn't do this thread without someone doing this.
I had a bad set, the distributor was brand new. But just like anything automotive, even new parts can go bad. The other distributor I had in the Daytona and the former Prestolite dual-points I had ran great for a long time.
Yeap, it had plenty of lube on the cam. It was a pretty new reman. distributor. I think it was a material defect on the portion of the points that makes contact with the distributor cam. Was worn down bigtime to the point where the apexes of the cam barely touched it, hence no point movement (opening/closing).
Mike, you know me pretty well now. I like to have as much as possible OEM looking. Now, do I HAVE to have the flame thrower II coil? Chrylser coils put out pretty good spark compared to other brands, correct? I experiemented yesterday with the 500. I installed the Pertronix unit Mike gave me (older version). I took the ballast resistor and took out the coil from behind. I installed a 16 gauge wire from one spade to the next, basically creating a direct 12v flow path. This in turn feeds the (+) side of the coil with 12v. I hooked the red wire of the Pertronix unit to the (+) side of the coil and the black wire to the (-) side of the coil. Fired her up and she ran great, no different than when I had the red wire of the Pertronix going straight to the 12v feed side of the ballast resistor. Again, I want the firewall area to be as OEM correct as possible. I plan on doing this to the Daytona and keeping the single points distributor as a back up for cruising..
Thanks guys...
Also, do you think I could install the Pertronix kit I have in a Prestolite dual-point distributor? I would like to also modidy the counter-weights to limit the total degree advance to 34, therby giving me the flexibility to increase the curb idle advance. It is my understanding that big block mopars enjoy higher initial advance settings, but due to OEM design, when you do that, it increases the total advance too much..
[Re: hemi68charger]
#912320
01/24/11 10:38 AM
01/24/11 10:38 AM
Posts: 15,487 Florida
scratchnfotraction
I used a #10 stranded wire and solderd the ends for the BR conversion yes,they should have a conversion for the prestolight duel points dist they have one for my mallory duellife duel point dist if it had points I think they make a conversion for it,even brigs&straton
[Re: scratchnfotraction]
#912321
01/24/11 11:09 AM
01/24/11 11:09 AM
hemi68charger
Houston, Tx
After going to Pertronix's website, apparently the kit I have is the 1st, the Ignitor. The early version is compatible with most OEM ignition coils. I just emailed their Support, I'll see what they say.
[Re: hemi68charger]
#912322
01/24/11 11:41 AM
01/24/11 11:41 AM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
The points had to have been opening slightly or the car would not have run. The spark occurs when they open, breaking the circuit and collapsing the electrical field in the coil causing a spark discharge.
It is not a good idea to have them closed for extended periods with the key on, as it can pit the points. If you didn't specifically use distributor cam lube, the plastic tang will quickly wear off. You can always use a matchbook cover to gauge the point gap out in the field. That will be close enough to get you home, where you can then use a dwell gauge to set the proper gap. Jeez, i'm dating myself aren't I?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: hemi68charger]
#912323
01/24/11 11:45 AM
01/24/11 11:45 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Don't bother with the ignitor I,...go with the Ignitor II, and use the Flame Thrower II,.....as I stated in the DC.com post,...use the Petronix Flame Thrower II epoxy filled coil, it's black in appearance, looks factory...the flame thrower is rated at 3 ohms and has a 100 turn ratio, were as the factory coil has 17 ohms and a 70 turn ratio,....using the factory coil on the Petronix set-up diminishes the HallCell output, and shortens it life
Mike
I'll look up the Petronix Ignitor II set-up for your Prestolite application tonight Troy, as there are about 6 applications for Mopar ignition set-ups
[Re: DAYCLONA]
#912324
01/24/11 12:08 PM
01/24/11 12:08 PM
hemi68charger
Houston, Tx
Mike
Thanks Mike... But man, those puppies are expensive... The FlameThrower coil seems to be well priced..
[Re: DAYCLONA]
#912325
01/24/11 12:34 PM
01/24/11 12:34 PM
hemi68charger
Houston, Tx
This is Mike? Pertronix 1382 Mopar 383413426 59-71 (may be the Ignitor series, not the Ignitor II's)
[Re: hemi68charger]
#912326
01/25/11 08:26 AM
01/25/11 08:26 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Troy that's the Ignitor I,...the Ignitor II is PN# PNX-91381A, you can only use this kit on the Chrysler distibutor,.....if you insist apon using the Prestolite unit then your stuck with the pn# PNX 1382 for the Ignitor I,.....I'd strongly recommend you purchase a rebuilt Chrysler RB SINGLE POINT dist for about $50, and run the PNX 91381A kit,....much more improvement over the earlier IGN I....the correct coils are Flame Thrower I PNX 40611, or for the Flame Thrower II, should you use the IGN II set up, PNX 45111,...I'd recommend you lose the ballast resistor in the system, you can still keep it for "looks" just gut it out, and solder in a #10 wire.
Mike
[Re: DAYCLONA]
#912327
01/25/11 08:36 AM
01/25/11 08:36 AM
hemi68charger
Houston, Tx
Mike
Thanks Mike.. I'll look up the Ignitor II/Flamethrower and find the best deal. I have two new single-point distributors already. For now, I'll keep the Ignitor I in the 500 since it's not going anywhere soon and I'll purchase an Ignitor II for the Daytona with the flamethrower. I couldn't find a Prestolite version of the Ignitor II. Right now can't afford nearly $300 for two II's at one pop... Also, I already have a ballast resistor with the #10 gut..
[Re: DAYCLONA]
#912329
01/25/11 09:53 AM
01/25/11 09:53 AM
RapidRobert
Put in another set of points & lube the cam/rubbing block sparingly/evenly & call it good for now. did the cam not get lubed or not completely covered? It had to wear down that fast/excessively for a reason & defective rubbing block hardened plastic could have been it but less likely
[Re: RapidRobert]
#912330
01/25/11 10:42 AM
01/25/11 10:42 AM
hemi68charger
Houston, Tx
There was plenty of lube on the rubbing block, it was a new remanufactured distributor. I took it back yesterday and got another one.... That's what's so weird. It totally looks like a defective rubbing block or a too strong point spring (I doubt that).
[Re: six-barrel]
#912332
01/26/11 12:42 AM
01/26/11 12:42 AM
hemi68charger
Houston, Tx
Thanks guys.. I communicated with Carl today from Pertronix... I will keep the Ignitor I for now in the '69 Charger 500 keeping all the other ignition components and tying into the 12v side of the ballast. I will soon purchase an Ignitor II & Flamethrower for the Daytona. I'll use the bypassed ballast resistor I made for that set-up. I have two new distributors for both applications..
Any experiments with the FBO advance limiter kit will come at a later time.
