Re: Sealing a log manifold to the head
[Re: 67_Satellite]
#911842
01/24/11 05:59 PM
01/24/11 05:59 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I never trusted Permatex to survive 1600+ degree heat. All kinds of gaskets from cheapies to soft copper were used on the hot rod but they always leaked. I never split the flange on these like I did on my last headers. Spliiting the old header flanges made it harder to install the headers due to the flex and they still leaked.
[Re: 67_Satellite]
#911844
01/25/11 03:29 AM
01/25/11 03:29 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
We have 1/2" flanges that were milled flat, no gaskets, only RTV. I think they might work even without RTV, but anyway, we have experienced no leaks.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#911845
01/25/11 11:14 AM
01/25/11 11:14 AM
feets
Senior Management
Senior Management
Irving, TX
My flanges are 1/2" cold rolled steel.
Jyrki, did you cut your flanges between the ports?
[Re: dOc …]
#911850
01/26/11 09:29 AM
01/26/11 09:29 AM
jyrki
Finalnd, Perkele
If you have a 0.001" gap between two particles it's way harder to blow through it than with a .040" gap. And if it really does happen, the .040" gap leaks significantly more than a .001" gap.
[Re: jyrki]
#911851
01/26/11 10:43 AM
01/26/11 10:43 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
www.remflex.comthey are good to 3000 F I'm a pipefitter by trade and the graphite used in these automotive gaskets is what we use for high heat / high pressure applications without failure.
