Sealing a log manifold to the head #911841
01/23/11 08:34 PM
01/23/11 08:34 PM
Andrews,In. U.S.of A.
67_Satellite Offline OP
After reading a number of posts about which gasket to use it seems that some guys have good luck using copper r.t.v. and nothing else.It also seems as though they are running heders and not logs. My concern was that the scrubbing of the stainless flange against the aluminum head would gouge up the head after a while and cause more problems. A log is going to expand and contract more than a header flange due to the body of the log growing with the heat. Has anyone ever tried using the cheap factory replacement gaskets in pairs? You know, the ones with stainless on one side,and soft gasket material on the other.I thought if you used r.t.v. or spray Permatex copper on the soft side and stuck it to the head,and stuck the soft side of the other to the log, then put antisieze between the stainless sides it might work. The harder stainless sides could slide against each other to allow movement without harming the heads sealing surface. The flange is split between the end ports and the center pair.I know the manifold grows quite a bit as it had tweaked the studs outward on the center pair of ports even with 9/16" holes around a 3/8' stud.Any thoughts?
Re: Sealing a log manifold to the head [Re: 67_Satellite] #911842
01/24/11 05:59 PM
01/24/11 05:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I never trusted Permatex to survive 1600+ degree heat. All kinds of gaskets from cheapies to soft copper were used on the hot rod but they always leaked. I never split the flange on these like I did on my last headers.
Spliiting the old header flanges made it harder to install the headers due to the flex and they still leaked.
- Stu Harmon
Re: Sealing a log manifold to the head [Re: feets] #911843
01/24/11 10:25 PM
01/24/11 10:25 PM
I think the root of the problem I had was the gaskets. I used the embossed copper,I think Mr. Gasket,and the port shape didn't align perfectly with the "bead" on the gasket.
Re: Sealing a log manifold to the head [Re: 67_Satellite] #911844
01/25/11 03:29 AM
01/25/11 03:29 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
We have 1/2" flanges that were milled flat, no gaskets, only RTV. I think they might work even without RTV, but anyway, we have experienced no leaks.
Plynouth VIP '67 TT IC EFI
Re: Sealing a log manifold to the head [Re: jyrki] #911845
01/25/11 11:14 AM
01/25/11 11:14 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My flanges are 1/2" cold rolled steel.
Jyrki, did you cut your flanges between the ports?
- Stu Harmon
Re: Sealing a log manifold to the head [Re: feets] #911846
01/25/11 10:54 PM
01/25/11 10:54 PM
IN
ahy Offline
ahy  Offline
IN
I've had good results with RTV only with headers in a NA application. I understand the concern about growing but the RTV will shear and let the parts slide if there is a lot of force... its a lot better than direct metal to metal which might lock the parts up. Since the head is water cooled, temps at the flange surface shouldn't be too extreme despite the high exhaust temps. I'd use the RTV.
Re: Sealing a log manifold to the head [Re: ahy] #911847
01/26/11 02:03 AM
01/26/11 02:03 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I'm assuming you are talking about a big block with the 3/8 exhaust bolt reference. I found these on Summit's website
.http://www.summitracing.com/parts/CGT-C5902-030/
They are MLS exhaust gaskets and that's what Cummins uses on their 5.9 and 6.7 diesels. They seem to hold up very well on those applications, even to the point of the manifolds cracking and falling apart, yet the flanges usually continue to seal up unless the bolts are broken.
I'd give them a try. In fact, I think I'm going to on my 440 with headers. Cheap gaskets included with the headers keep leaking worse and worse.
Re: Sealing a log manifold to the head [Re: dodgeboy11] #911848
01/26/11 03:36 AM
01/26/11 03:36 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
We have a common flange.
Re: Sealing a log manifold to the head [Re: jyrki] #911849
01/26/11 05:04 AM
01/26/11 05:04 AM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
Some are blowing-out soft copper ... and then others having good luck with RTV ......
Re: Sealing a log manifold to the head [Re: dOc …] #911850
01/26/11 09:29 AM
01/26/11 09:29 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
If you have a 0.001" gap between two particles it's way harder to blow through it than with a .040" gap. And if it really does happen, the .040" gap leaks significantly more than a .001" gap.
Re: Sealing a log manifold to the head [Re: jyrki] #911851
01/26/11 10:43 AM
01/26/11 10:43 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
www.remflex.com
they are good to 3000 F
I'm a pipefitter by trade and the graphite used in these automotive gaskets is what we use for high heat / high pressure applications without failure.
Re: Sealing a log manifold to the head [Re: jyrki] #911852
01/26/11 08:33 PM
01/26/11 08:33 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
This is the key. If you have no gasket, it can't fail. As soon as you use a gasket you're doomed. The first time you tighten the flange to the head with a gasket you bend/ warp it, because the gasket compresses. You dont need gaskets if you made the exhaust right.
Re: Sealing a log manifold to the head [Re: TRENDZ] #911853
01/26/11 10:58 PM
01/26/11 10:58 PM
Well, since it's $30-$40 cheaper,I'm going to try the no gasket route first.I'll probably still try some of the copper spray coat on it too. The offending manifold is at my local machine shop now,and he is going to run it across the head surfacer(giant beltsander)for me to insure a flat surface. We'll see how it goes. Thanks for all the ideas/suggestions.
Re: Sealing a log manifold to the head [Re: 67_Satellite] #911854
01/26/11 11:11 PM
01/26/11 11:11 PM
Florida STAYcation
Florida STAYcation
IF it is TRULY flat .. there should not be a problem. Some are saying and comparing manifolds that are 001 ...and 040 "out-of-wack".
USING a gasket that will "insulate" the manifold from the head can be a major bummer SINCE the heat from the manifold(especially the flange area) ... bleeds-off TO the head.
Re: Sealing a log manifold to the head [Re: dOc …] #911855
01/28/11 02:42 AM
01/28/11 02:42 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Machine the flange and use high temp RTV. I hae never had a leak that way but the flange needs to be straight. What most people forget about a turbo application is the fact that there is alot of back pressure in the manifold compared to a N/A app. When I ran my old motor I had 26 psi of back pressure for about 14 psi boost. With the thin layer of RTV and a straight flange the pressure has no gasket or weak area to push out. It just seals.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Sealing a log manifold to the head [Re: CW25] #911856
01/30/11 10:16 AM
01/30/11 10:16 AM
It's all back together ,machined flat,cleaned both surfaces with brake clean,coated the manifold with copper spray. And the ace-in-the-hole, I added 2 5/16"X24 studs between the center ports on the top and bottom of the flange.(does best Homer Simpson "There,take that.")
Re: Sealing a log manifold to the head [Re: 67_Satellite] #911857
01/30/11 11:06 PM
01/30/11 11:06 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
all turbo exhaust manifolds should have two modifications. Slightly larger bolt holes for extra room due to heat expansion. where possible split the flange between the cylinders for the same reasons.
Gasket blowout becasue the mating surfaces are not flush or even close in many cases. Most convention header leaks come from uneven surface on their flages.
There half a biilon cars on the globe without gaskets. Every S/B Chevy is a good example. on cast factory manifolds we always surface them to insure a good seal..
home of the
Sox and Martin Hemi Duster
