Mopar techs-front pump trans seal leaking in 300M #91183
07/20/08 11:37 AM
07/20/08 11:37 AM
Westfield, MA
rbrogle Offline OP
super street
rbrogle  Offline OP
super street
Westfield, MA
At 141,000 miles, I am finally having my first repair to my '00 300M. I love this car! I have a few questions:
1. A local tranny shop that I deal with will replace the seal and do the entire job for around $800. It seems like a fair price to me given the labor? Is it fair?
2. Should they do anything else to the tranny while it is out of the car, like replace the converter?
3. Anything else I should know or watch out for?
Thanks in advance!
Rob '70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic '68 300 2 Door HT vinyl/cloth bench '68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED! '68 New Yorker 4 Door HT, 440/Auto, loaded! 2004 Chrysler 300M Special daily driver
Re: Mopar techs-front pump trans seal leaking in 300M [Re: rbrogle] #91184
07/20/08 02:50 PM
07/20/08 02:50 PM
ky.
K
kenworth_goose Offline
K
ky.
It's not the front seal causing the leak. It's the bushing behind the seal. They won't tell you until they get it out. The brass bushing in the pump wears, then covers the return hole occasionaly and then it will leak. The convertor can also be worn because of the brass bushing also. At 141k I'd rebuild the entire trans. And make sure to get a new convertor.
Re: Mopar techs-front pump trans seal leaking in 300M [Re: kenworth_goose] #91185
07/20/08 09:51 PM
07/20/08 09:51 PM
Westfield, MA
rbrogle Offline OP
super street
rbrogle  Offline OP
super street
Westfield, MA
Wow, that's a kick in the head. How much do you figure to rebuild the entire transmission if that truly is the case.
Thanks again, I'd rather have an idea about upcoming pain than not!
Re: Mopar techs-front pump trans seal leaking in 300M [Re: rbrogle] #91186
07/20/08 09:55 PM
07/20/08 09:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
With that kind of mileage and it had to be pulled for a leak or similar condition, I would definitly go thru it
without putting pencil to paper I would figure $1500 to $2000, with 2K on the high side/ worst case
Re: Mopar techs-front pump trans seal leaking in 300M [Re: gtx6970] #91187
07/21/08 01:02 PM
07/21/08 01:02 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
price will vary in different regigns he in Central Fl our shop would be around 2400 for a full overhaul with converter depending on actual damage.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
