Please check my 8 3/4 measurements.
#911777
01/23/11 07:50 PM
01/23/11 07:50 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
I crawled under the 69 Cuda and plumb bobbed down to the level concrete and came up with these measurements. Spring perch centerline to centerline is 43.00 inches, axle housing flange to flange Centerline is 52", axle flange to axle flange centerline is 57 1/2". We are about to order a Dana 60 for the Cuda and we want to make sure that this is correct. Someone told me that the housing SHOULD measure 51 1/2 inches center to center of axle housing flanges.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
Re: Please check my 8 3/4 measurements.
[Re: PUNK]
#911779
01/23/11 10:01 PM
01/23/11 10:01 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I have seen A body 8 3/4 housing measure like yours and some measure a little shorter, that is with the center section out measuring across the front sides, Mopars factory spec. of + or - minus a yard is pretty close isn't it If the housing is tweek a little forward or backwards, up or down a little that will add to the differences also I ordered my strange 35 spline axles for the A body brakes back when, not the B,E and C body brakes. There is a differences in the distances from the axle bearing seats to the outside of the axle flanges I think that I would order off of (worry about) the spring perch centers and the outside of the axle flange to the other outside axle flange measurements don't forget the pinion offsets and spring perch angles Are you guys going to MATS this year?
