Re: excessive oling to top end
[Re: hvyweight]
#911679
01/23/11 05:54 PM
01/23/11 05:54 PM
Posts: 2,091 Delray beach, Florida
Performance Only
what size oil returns and how do you have them routed back to the pan? after 3 minues of running a drill, you might just have a return problem and not an over oiling problem. i normally use a much smaller orifice in the pushrods that what your using. .035 should be plenty. a picture of your setup might help.
machine shop owner and engine builder
[Re: sg66mopar]
#911690
01/23/11 10:51 PM
01/23/11 10:51 PM
Posts: 6,295 U.S.
moparniac
U.S.
Sg! If your engine is apart I noticed on my world aluminum block on the number 4 to oil up top had the right cam bearings to oil but there was NO holes regardless for oil to go up top ! I noticed this recently after taking the cam bearings out! I never really took notice or cared before cause I plugged up on the decks regardless .
Mopar Performance
