excessive oling to top end #911678
01/23/11 05:40 PM
01/23/11 05:40 PM
Winterpeg, Canada
hvyweight Offline OP
Winterpeg, Canada
I think that I have excessive oiling to the rockers....
World product alum block, B1MC heads (front and back oil rtns) with jesel rockers. Tall isky ez roll lifters for pushrod oiling .090 orfice. Manton hollow pushrods with a .075 orfice in them. Priming the engine I have about 75-80 pounds. I roll the motor over with a breaker bar to see if the oil is reaching the rocker. All are getting oil but the outer lifters ie 1 exhaust and 7 exhaust are getting less oil. I am using Brad Penn break in getting ready for the dyno. I spun the drill rotating the motor for about three minutes then let it sit. I removed the valve cover and seen where the oil was sitting in the valve cover about and inch up from the mounting surface of the valve cover. I know that B1 have terrible drain back. So what do you guys think too much oil to the top?
Mike
Re: excessive oling to top end [Re: hvyweight] #911679
01/23/11 05:54 PM
01/23/11 05:54 PM
Delray beach, Florida
P
Performance Only Offline
P
what size oil returns and how do you have them routed back to the pan? after 3 minues of running a drill, you might just have a return problem and not an over oiling problem.
i normally use a much smaller orifice in the pushrods that what your using. .035 should be plenty.
a picture of your setup might help.
machine shop owner and engine builder
Re: excessive oling to top end [Re: Performance Only] #911680
01/23/11 06:05 PM
01/23/11 06:05 PM
Winterpeg, Canada
Winterpeg, Canada
I have a #8 rtn line. The orfice in the pushrods is what Manton suggested. I'll get some pics here right away!
Re: excessive oling to top end [Re: hvyweight] #911681
01/23/11 06:16 PM
01/23/11 06:16 PM
detroit area
moderncylinder Offline
detroit area
also,, how thick was the oil? was it in your cold garage when priming? how cold was the oil?
id use -10 lines,,
.025 or so in pushrod/lifter
Re: excessive oling to top end [Re: moderncylinder] #911682
01/23/11 06:26 PM
01/23/11 06:26 PM
Winterpeg, Canada
Winterpeg, Canada
30 wt Brad Penn. It was about 70 maybe 75 in the shop. Oil was at room temp.
Any ideas about the outer lifters not receiving as much oil. I checked every lifter, pushrod and rocker with compressed air everything is clean and no obstructions?
Re: excessive oling to top end [Re: hvyweight] #911683
01/23/11 07:00 PM
01/23/11 07:00 PM
Winterpeg, Canada
Winterpeg, Canada
pic of rockers
Re: excessive oling to top end [Re: hvyweight] #911684
01/23/11 07:03 PM
01/23/11 07:03 PM
Winterpeg, Canada
Winterpeg, Canada
pic 2
Re: excessive oling to top end [Re: hvyweight] #911685
01/23/11 07:58 PM
01/23/11 07:58 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I have one .065" jet that does the entire top end .
You got a boatload of oil going up there .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: excessive oling to top end [Re: go green] #911686
01/23/11 10:06 PM
01/23/11 10:06 PM
sg66mopar Offline
sg66mopar  Offline
I'm wondering about this too. I'm in the process of changing from Koffel's rockers to T&D individual shaft rockers with pushrod oil. My World aluminum block came from the factory with one .040 hole on each side to supply all the rocker oil. With the pushrod oiling you've got 8 holes sending oil up there!
Once the oil gets up to 180 or so it'll drain back a lot faster but still?
A couple of the other guys on here that know their S**t tell me it won't be a problem.
Re: excessive oling to top end [Re: hvyweight] #911687
01/23/11 10:06 PM
01/23/11 10:06 PM
Is the motor leveled to the floor now? Will the motor be leveled in the car or tilted down some in the rear in the car? If tilted in the car try tilting the front up some when priming and let us know your results
Re: excessive oling to top end [Re: go green] #911688
01/23/11 10:41 PM
01/23/11 10:41 PM
Winterpeg, Canada
Winterpeg, Canada
How are you restricting to .065 for the entire top end?.
Re: excessive oling to top end [Re: Cab_Burge] #911689
01/23/11 10:46 PM
01/23/11 10:46 PM
Winterpeg, Canada
Winterpeg, Canada
I tried it with the nose up on the engine stand and level as well. I guess I'm not super concerned with the amount of oil up top. But I'm concerned with the return. I was think about a drain back in the valve cover just above the valve cover rail. I know it won't lessen the problem of oil coming to the top of the engine but should help the return issue! What do ya think?
Re: excessive oling to top end [Re: sg66mopar] #911690
01/23/11 10:51 PM
01/23/11 10:51 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Sg! If your engine is apart I noticed on my world aluminum block on the number 4 to oil up top had the right cam bearings to oil but there was NO holes regardless for oil to go up top ! I noticed this recently after taking the cam bearings out! I never really took notice or cared before cause I plugged up on the decks regardless .
Mopar Performance
Re: excessive oling to top end [Re: hvyweight] #911691
01/24/11 12:12 AM
01/24/11 12:12 AM
go green Offline
go green  Offline
I have a Jet in the bulkhead fitting in the block.
Re: excessive oling to top end [Re: go green] #911692
01/24/11 01:08 AM
01/24/11 01:08 AM
Winterpeg, Canada
Winterpeg, Canada
cool pic!
I should have added that there is .020 orfice in the bushings in the lifter bores
Re: excessive oling to top end [Re: go green] #911693
01/24/11 01:10 AM
01/24/11 01:10 AM
Sk
sp6162 Offline
sp6162  Offline
Sk
Nice system Dean!
Hey Mike, Doesn't your block has .020" feed holes in your lifter bushings?
If so, that's all your lifters and pushrods will see.
I'm not sure if that is still too much.
Re: excessive oling to top end [Re: sp6162] #911694
01/24/11 01:15 AM
01/24/11 01:15 AM
Winterpeg, Canada
Winterpeg, Canada
Mike
Yeah your right about the 020 hole in the bushing. I am thinking that its the smallest hole in the system so regardless of the 075 in the pushrod it shouldn't matter right?
Re: excessive oling to top end [Re: go green] #911695
01/24/11 01:21 AM
01/24/11 01:21 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Real nice system you have there, can you explain what it is for?
Re: excessive oling to top end [Re: rowin4] #911696
01/24/11 02:40 AM
01/24/11 02:40 AM
go green Offline
go green  Offline
Necessity is the mother of all invention .
No one in town could or would guarantee drilling the block out for lifter valley oil galleries and shipping it back to KB would be to expensive.
So I did it myself by plumbing it individually.
Re: excessive oling to top end [Re: go green] #911697
03/06/11 03:23 PM
03/06/11 03:23 PM
Winterpeg, Canada
Winterpeg, Canada
We'll dyno the motor and it didn't go well. Lots of little things. Decided to take the bottom end apart and discovered #5 rod bearing went for s#$%. Started looking at things and I am convinced that I have to much oil to the top. I noticed that the oiling hole in the lifter was in the same path of travel as the bushing in the lifter bore. I have .002 clearance between the lifter and the lifter bore. I was thinking that the clearance would act like a restrictor. I am now thinking that maybe I should put a restrictor in my Manton pushrods or take the lifter bushings out and turn them 90 degrees. What do you guys think?
