Painting a Steering Wheel? #911348
01/23/11 10:56 AM
01/23/11 10:56 AM
North NJ
a6t9vette Offline OP
North NJ
I picked up a dark brown wheel for my 69 RR, and looking to freshen it up and change color to black. I dont think I could get a good/durable finish on it with a rattle can so was planning on taking to a local shop to have them spray it. Has anyone done this? Any recommendations on what paint to use, or what finish? Rather then the shop doing some trial and error I was hoping someone has done this.
Note this is the base model wheel (no center triangle), just your basic 3 spoke wheel.
69 Road Runner, numbers matching 383, Auto.
Re: Painting a Steering Wheel? [Re: a6t9vette] #911349
01/23/11 11:21 AM
01/23/11 11:21 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I would use rattle-can SEM Landau Black...couple of nice thin coats...If you're worried about it wearing off, you could add a couple of coats of SEM semi-gloss clear.
CHECK OUT MY NEW WEB SITE !
Re: Painting a Steering Wheel? [Re: a6t9vette] #911350
01/23/11 12:52 PM
01/23/11 12:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Clean it well, scuff it with a scotchbright pad and use a high quality vinyl & plastic spray paint.
Re: Painting a Steering Wheel? [Re: jbc426] #911351
01/23/11 01:12 PM
01/23/11 01:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
With both of you guys...do it yourself, your'll be glad you did. Have fun.
Re: Painting a Steering Wheel? [Re: Challenger 1] #911352
01/23/11 03:25 PM
01/23/11 03:25 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
If you want to use SEM or any other good rattle can paints, the key to making them stick is proper preparation. Use the SEM vinyl/plastic cleaner before and after sanding or scuffing.
If you don't trust yourself, you can have your body shop paint it with the same thing they use for painting flexible bumper covers. The paint they use has added flex agents and binders just for painting this type of material.
