60ft times vs tire height #911047
01/22/11 09:03 PM
01/22/11 09:03 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i was wondering if my 60fts would improve with a shorter tire height,88 dakota 3340# 418cid, 9.7 compression, pump gas small block stroker,about 470 hp,driven to the track, 727 reverse pattern lba tranny.ptc 10" converter, flashes 4200, 8 3/4 3.91 posi,stock front /rear shcks with cal/trac bars, m/t drag radial 295/65-15.1st time at track with new motor it ran 7.31@94.5 with a 1.64 60ft.im thinking about going to a m/t drag radial 275/60-15 or a 325-50-15 which are 28"tall instead of 30 like the current 295-65-15?i was thinking the tall tire was hurting my off the line gearing?
Re: 60ft times vs tire height [Re: hp340nos] #911048
01/22/11 10:24 PM
01/22/11 10:24 PM
Yes, shorter tire will definitely help your 60 foot.I tried to go as small up front as possible without the car looking ridiculous.
Re: 60ft times vs tire height [Re: hp340nos] #911049
01/22/11 10:50 PM
01/22/11 10:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Granted those are tall tires for your gear but better
shocks would also help you
Re: 60ft times vs tire height [Re: MR_P_BODY] #911050
01/22/11 11:18 PM
01/22/11 11:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the shorter tire also reduces contact patch and may cause traction issues if the car is not set up well. so it could actually slow you down if you can't hook.
Re: 60ft times vs tire height [Re: Quicktree] #911051
01/22/11 11:36 PM
01/22/11 11:36 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
yes thats what i figured adjustable front/rear shocks would help weight transfer also.
Re: 60ft times vs tire height [Re: hp340nos] #911052
01/22/11 11:36 PM
01/22/11 11:36 PM
NC
barracuda man Offline
NC
maybe try some 4.56 or 488 gears.should net a 1.55 60'times.
Re: 60ft times vs tire height [Re: hp340nos] #911053
01/23/11 02:28 AM
01/23/11 02:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Also think of it this way... its cheaper to change
a gear than it is to buy a set of tires.... tires
about $450 and a gear and set up is $320 or less
Re: 60ft times vs tire height [Re: MR_P_BODY] #911054
01/23/11 03:01 AM
01/23/11 03:01 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
the tires are at the wear bars m/t drag radials,thats why i was asking about shorter tires.thanks mike
Re: 60ft times vs tire height [Re: hp340nos] #911055
01/23/11 04:14 AM
01/23/11 04:14 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
You can change the drive ratio either way, which should help. Leaving a taller tire on it and changing the gear would give a bigger footprint and would be the preferred method. As mentioned, you can do it with shorter tires, but it may take some additional time in chassis tuning.
Good Luck
Re: 60ft times vs tire height [Re: TheBlackCar] #911056
01/23/11 01:53 PM
01/23/11 01:53 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
the truck is street driven to the track.4.56/4.88 seem a little low for the street to me.i know i cant have best of both worlds street/strip,just trying to improve 60 fts some is all.
Re: 60ft times vs tire height [Re: hp340nos] #911057
01/23/11 02:19 PM
01/23/11 02:19 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I run 4.56's with a 30" tall tire. Street driven most of the time, 1.60 60' times with a 3900# car. At 60 MPH I'm taching 3100 rpm.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 60ft times vs tire height [Re: 68LAR] #911058
01/23/11 02:57 PM
01/23/11 02:57 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
I have a 28" tall tire and have a 1.35-1.36 60 ft
I would suggest look at shocks and other chassis adjustments
Re: 60ft times vs tire height [Re: Dartman928] #911059
01/24/11 04:38 AM
01/24/11 04:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run 4.30's with a 30" tall tire myself in my 63 with a mild 440. It goes 3700 lbs with me in it and my best 60 is a 1.57 with my average in the low 1.60's on tracks with not so great hook. It works good for my street driving as with my 9.5 Dynamic converter it tachs about 3100 at 60 mph. I drive it on the highway all the time as I drive it the 45 miles to the track also. More gear might help your 60 but I would think suspension help should work also as you are much lighter then my 63 and should 60 ft as good or better then I do. My 63 is about 500 flywheel hp and has a best 1/8 of 7.28 @ 93.74 mph and a best 1/4 of 11.49 @ 116. And my converter flashes about 4200 and works real nice. Good luck , Ron
Re: 60ft times vs tire height [Re: hp340nos] #911060
01/24/11 05:32 AM
01/24/11 05:32 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
i was wondering if my 60fts would improve with a shorter tire height,88 dakota 3340# 418cid, 9.7 compression, pump gas small block stroker,about 470 hp,driven to the track, 727 reverse pattern lba tranny.ptc 10" converter, flashes 4200, 8 3/4 3.91 posi,stock front /rear shcks with cal/trac bars, m/t drag radial 295/65-15.1st time at track with new motor it ran [Email]7.31@94.5[/Email] with a 1.64 60ft.im thinking about going to a m/t drag radial 275/60-15 or a 325-50-15 which are 28"tall instead of 30 like the current 295-65-15?i was thinking the tall tire was hurting my off the line gearing?
I think your combo would be helped with a shorter tire BECAUSE the combo should have a taller gear in it.
BUT ... if the car is geared correctly .... I don't see how a shorter tire would help 60 foot times. Now reaction times ... that is another story.
Re: 60ft times vs tire height [Re: dOrk !] #911061
01/24/11 06:07 AM
01/24/11 06:07 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
it would also look better w/ shorter rear tires IMO
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
