A-body K-Frame notching #910889
01/22/11 06:42 PM
01/22/11 06:42 PM
Indiana
W5Duster436 Offline OP
Indiana
Just got done pulling the engine out of the duster and before the new one goes in I want to notch/modify the k-frame so it's much easier putting it in with this moroso oil pan with the bellhousing attached. I have heard that there used to be instructions from either Moroso or Milodon for doing this but can't remember which had the big issue. I know this Moroso pan is a major PITA to get installed with the blowproof connected. I figure if I notch the heck out of the k-frame it'll be much easier to install.
Anyone have pics of what they have done on theirs to allow easier access to install engine with bellhousing attached?
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: A-body K-Frame notching [Re: W5Duster436] #910890
01/22/11 06:54 PM
01/22/11 06:54 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
make 2 slices along the lip,as wide as u can and hammer the lip down,fold it under,doesn't affect the strengh
Re: A-body K-Frame notching [Re: fishy340] #910891
01/22/11 07:01 PM
01/22/11 07:01 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
go crazy, i have loads of clearence for my pan
Re: A-body K-Frame notching [Re: rebel] #910892
01/22/11 07:05 PM
01/22/11 07:05 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Or this >>>>>>[image]http://[/image]
Re: A-body K-Frame notching [Re: rebel] #910893
01/22/11 07:14 PM
01/22/11 07:14 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
fellas if thats what u call notching,WOW,THATS ALTERING TO ME..lol
Re: A-body K-Frame notching [Re: fishy340] #910894
01/22/11 07:20 PM
01/22/11 07:20 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
LOL, i just started cutting and said what the heck, [image]http://[/image]
Re: A-body K-Frame notching [Re: Randy..] #910895
01/22/11 07:27 PM
01/22/11 07:27 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Randy ever weight that to see if there were any saving in weight?That looks pretty simple. and what size tubing were used between the the two sections Thaxx
Re: A-body K-Frame notching [Re: racerx] #910896
01/22/11 07:42 PM
01/22/11 07:42 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Best i can remember it was between 10/13lbs, does not seem like much but after it was finished i could hold it straight out in front of me with one arm extended. the round tube is <cheap> 1 1/2 mild steel. :twocents [image]http://[/image]
Re: A-body K-Frame notching [Re: Randy..] #910897
01/22/11 07:52 PM
01/22/11 07:52 PM
Indiana
Indiana
Wow, lots of different ways I guess. I was only planning on notching a bit out of it by getting rid of that lip and then a small part of the top where the pan always hits.
'71 Dodge D100
'70 Dodge W100
Re: A-body K-Frame notching [Re: fishy340] #910898
01/22/11 07:54 PM
01/22/11 07:54 PM
Indiana
Indiana
This is pretty much what I had planned and then maybe a small notch on the main part of the frame.
'71 Dodge D100
'70 Dodge W100
Re: A-body K-Frame notching [Re: W5Duster436] #910899
01/22/11 09:31 PM
01/22/11 09:31 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yes my man simple to do,its 2 pc pressed together,sawzall 2 notches and light tapping it folds over like butter
Re: A-body K-Frame notching [Re: fishy340] #910900
01/22/11 09:51 PM
01/22/11 09:51 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Do you have to remove the torsion bars when you do this? Things don't twist and get out of wack with them in? Thought about doing this to mine but was worried about keeping it all straight.
Re: A-body K-Frame notching [Re: rebel] #910901
01/22/11 09:54 PM
01/22/11 09:54 PM
8
80arrow Offline
80arrow  Offline
Rebel
Looks sweet. Got any more pics of the rack set-up? Did you use the stock steering arms? What kind of rack?
Re: A-body K-Frame notching [Re: 80arrow] #910902
01/22/11 09:56 PM
01/22/11 09:56 PM
8
80arrow Offline
80arrow  Offline
Rebel
forget that last part, I see your steering is on the wrong side.
Re: A-body K-Frame notching [Re: 80arrow] #910903
01/22/11 09:56 PM
01/22/11 09:56 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Rebel
You'll have to get used to driving from the other side of the car
If you like drag racing, support your local track.
Re: A-body K-Frame notching [Re: 80arrow] #910904
01/22/11 10:17 PM
01/22/11 10:17 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Rebel
i'm sure a pinto rack or something similar could be adapted to suit. altho my main body shell was stamped out with all the other darts, the firewall was an Australian part.
Re: A-body K-Frame notching [Re: rebel] #910905
01/22/11 10:42 PM
01/22/11 10:42 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I recall something on where to cut the k but I thought it was in a magazine, anyway I did mine that way and it does give more clearance but if I did it again I would cut from the steering box flat area forward , cut the other side the same width and put a bent pipe in between .When I did mine I used 11 gage { 1/8" ] x 4" flat stock, welded in to the cut out area and ground off what was left sticking up/ down. Should have cut the drivers side wider as the pan is about 1/8" from the k.
Re: A-body K-Frame notching [Re: W5Duster436] #910906
01/24/11 12:37 PM
01/24/11 12:37 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: A-body K-Frame notching [Re: fishy340] #910907
04/30/11 07:53 PM
04/30/11 07:53 PM
Indiana
Indiana
Just got done doing this today and I can tell you there's no "Light tapping" to it.
Worked like a champ though.. Hopefully I'll have the engine back in a few weeks to drop in and try it out.
'71 Dodge D100
'70 Dodge W100
Re: A-body K-Frame notching [Re: W5Duster436] #910908
04/30/11 08:11 PM
04/30/11 08:11 PM
rowin4 Offline
rowin4  Offline
Well, I see you didn't rush right into it
