A-body K-Frame notching
#910889
01/22/11 06:42 PM
01/22/11 06:42 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
Just got done pulling the engine out of the duster and before the new one goes in I want to notch/modify the k-frame so it's much easier putting it in with this moroso oil pan with the bellhousing attached. I have heard that there used to be instructions from either Moroso or Milodon for doing this but can't remember which had the big issue. I know this Moroso pan is a major PITA to get installed with the blowproof connected. I figure if I notch the heck out of the k-frame it'll be much easier to install.
Anyone have pics of what they have done on theirs to allow easier access to install engine with bellhousing attached?
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
Re: A-body K-Frame notching
[Re: Randy..]
#910897
01/22/11 07:52 PM
01/22/11 07:52 PM
W5Duster436
Indiana
Wow, lots of different ways I guess. I was only planning on notching a bit out of it by getting rid of that lip and then a small part of the top where the pan always hits.
[Re: 80arrow]
#910902
01/22/11 09:56 PM
01/22/11 09:56 PM
Posts: 814 in front of the computer
80arrow
go crazy, i have loads of clearence for my pan
Rebel
Looks sweet. Got any more pics of the rack set-up? Did you use the stock steering arms? What kind of rack?
forget that last part, I see your steering is on the wrong side.
[Re: rebel]
#910905
01/22/11 10:42 PM
01/22/11 10:42 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I recall something on where to cut the k but I thought it was in a magazine, anyway I did mine that way and it does give more clearance but if I did it again I would cut from the steering box flat area forward , cut the other side the same width and put a bent pipe in between .When I did mine I used 11 gage { 1/8" ] x 4" flat stock, welded in to the cut out area and ground off what was left sticking up/ down. Should have cut the drivers side wider as the pan is about 1/8" from the k.
