97 5.9 cam to crank timing question... #910724
01/22/11 04:17 PM
01/22/11 04:17 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
Heads are off, rotor pointing at number 1, crank at TDC, number 1 piston at TDC, timing mark on crank gear at 12:00...why is the cam gear timing mark at 12:00 and not 6:00????? This was a running 5.9 when taken apart to replace head gaskets. My brother was just checking everything before he pulled the cam out. Help...it's cold out today...
BigBlock 74 Swinger
Re: 97 5.9 cam to crank timing question... [Re: bb74swngr] #910725
01/22/11 04:20 PM
01/22/11 04:20 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
cause it is suppose to be 12 o'clock ...that is correct...if the cam gear is at 6 ...it is at no. 6 firing...
everyone uses the 6 on cam ..and 12 on crank ...easier to line up...
Tony
70 AARCuda Vitamin C
Re: 97 5.9 cam to crank timing question... [Re: 70AARcuda] #910726
01/22/11 04:23 PM
01/22/11 04:23 PM
Missouri
mopar addict
mopar addict
Missouri
That's the problem. This engine has not be touched since tear-down, yet at TDC the cam gear timing mark is at 12:00 also. I agree with you but that is not what we have...
BigBlock 74 Swinger
Re: 97 5.9 cam to crank timing question... [Re: bb74swngr] #910727
01/22/11 04:28 PM
01/22/11 04:28 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
You did not read and understand his answer, which is CORRECT
When you set up a new engine, with crank at 12 and cam at 6, THAT SITUATION is NOT no 1 ready to fire, it is no 6 ready to fire
Your engine as it sits is correct and just fine. If you were to wrench it around so that "what you think is correct" that is, crank at 12:00, cam at 6:00 and lined up, you would see that the rotor points to no6.
YOU WOULD ALSO SEE at this lineup that both valves for no1 are partly open (close to what used to be called "split overlap") and that both no6 valves are "closed and loose" --ready to fire
Re: 97 5.9 cam to crank timing question... [Re: Yancy Derringer] #910728
01/22/11 04:32 PM
01/22/11 04:32 PM
Missouri
mopar addict
mopar addict
Missouri
Thank you so much Tom and Tony! What you said is what we have...just didn't seem right. I have a lot to learn!!!! We will re-install just as you say:)
Thanks again guys...
Russ and Tim:)
BigBlock 74 Swinger
