how much hp do you think i'm gonna gain? #910212
01/21/11 01:39 PM
01/21/11 01:39 PM
colorado
1badD50 Offline OP
1badD50  Offline OP
colorado
just sent my magnum eddy heads and single plain magnum intake to Jeff at modern to get fully ported, Was wondering if you guys had any ideas how much horse power im gonna gain just looking for a ball park idea i know its hard to know for sure
Re: how much hp do you think i'm gonna gain? [Re: 1badD50] #910213
01/21/11 01:54 PM
01/21/11 01:54 PM
organ
maximum entropy Offline
organ
depends on your combo. if the porting is optimized for your cam (and vice versa), you could see pretty significant gains. jeff would probably have a pretty good idea what you could gain.
Re: how much hp do you think i'm gonna gain? [Re: 1badD50] #910214
01/21/11 02:07 PM
01/21/11 02:07 PM
NC
440Jim Offline
440Jim  Offline
NC
If your combo can support it, the flow gain could be worth up to 2 hp per cfm gained. So if the head flow goes up 30 cfm, it will support 60 more hp... if the rest of the combo will support it. Rough, but without any other info, that is all I can offer.
Re: how much hp do you think i'm gonna gain? [Re: 440Jim] #910215
01/21/11 02:19 PM
01/21/11 02:19 PM
colorado
1badD50 Offline OP
1badD50  Offline OP
colorado
The cam is about .588 lift intake and .595 or so on exhaust not sure of the duration dont have the cam card in front of me, but thanks a bunch for the info
Re: how much hp do you think i'm gonna gain? [Re: 1badD50] #910216
01/21/11 05:52 PM
01/21/11 05:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I doubt if you are even come close to using the extra air flow with that cam. but you should still see an improvement from the low lift numbers.
Re: how much hp do you think i'm gonna gain? [Re: 1badD50] #910217
01/21/11 06:05 PM
01/21/11 06:05 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I'm sure,if you gave all of your information to Jeff,you will be happy with the results.
I have never used him personally,but he knows what he is doing.
Keith
Re: how much hp do you think i'm gonna gain? [Re: Dunnuck Racing] #910218
01/22/11 06:48 PM
01/22/11 06:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
We run mostly 1/8th down here in NC, Just had Shady Dell do a Stage 2 (from maybe 240-ish to 270+) on my Eddies for my 12:1 414, hoping that ~30cfm nets me another 50 or so HP, which for me also allows me a higher RPM cieling to where I won't have to take gear out of my comb when I run the 1/4.
As said it really depends on the rest of the combo, and if the short block you have has hit it's "saturation point" VE wise with the Compression, cam and induction you have. In other words is it to the point where Head flow is the main thing holding it back (causing/resulting in the power falling off)
WIZE
In Car:
Re: how much hp do you think i'm gonna gain? [Re: Streetwize] #910219
01/22/11 06:52 PM
01/22/11 06:52 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i spent crazy money having ray barton do my eddies,they said 311cfm which was way off the local shops flow bench..2600 for a tenth..mistake that wont be made again,car did 10.90's after it did 10.80's
Re: how much hp do you think i'm gonna gain? [Re: fishy340] #910220
01/22/11 07:34 PM
01/22/11 07:34 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
2,600 for 10 hp
Re: how much hp do you think i'm gonna gain? [Re: cbarracuda] #910221
01/22/11 09:34 PM
01/22/11 09:34 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: how much hp do you think i'm gonna gain? [Re: cbarracuda] #910222
01/22/11 09:53 PM
01/22/11 09:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
2,600 for 10 hp
there are so many things that could have caused that other than the heads.
