Re: how much hp do you think i'm gonna gain?
[Re: 1badD50]
#910213
01/21/11 01:54 PM
01/21/11 01:54 PM
Posts: 5,080 organ
maximum entropy
organ
depends on your combo. if the porting is optimized for your cam (and vice versa), you could see pretty significant gains. jeff would probably have a pretty good idea what you could gain.
[Re: 1badD50]
#910216
01/21/11 05:52 PM
01/21/11 05:52 PM
Quicktree
The cam is about .588 lift intake and .595 or so on exhaust not sure of the duration dont have the cam card in front of me, but thanks a bunch for the info
I doubt if you are even come close to using the extra air flow with that cam. but you should still see an improvement from the low lift numbers.
[Re: 1badD50]
#910217
01/21/11 06:05 PM
01/21/11 06:05 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I'm sure,if you gave all of your information to Jeff,you will be happy with the results. I have never used him personally,but he knows what he is doing. Keith
[Re: Dunnuck Racing]
#910218
01/22/11 06:48 PM
01/22/11 06:48 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
We run mostly 1/8th down here in NC, Just had Shady Dell do a Stage 2 (from maybe 240-ish to 270+) on my Eddies for my 12:1 414, hoping that ~30cfm nets me another 50 or so HP, which for me also allows me a higher RPM cieling to where I won't have to take gear out of my comb when I run the 1/4. As said it really depends on the rest of the combo, and if the short block you have has hit it's "saturation point" VE wise with the Compression, cam and induction you have. In other words is it to the point where Head flow is the main thing holding it back (causing/resulting in the power falling off)
[Re: cbarracuda]
#910222
01/22/11 09:53 PM
01/22/11 09:53 PM
Quicktree
2,600 for 10 hp
there are so many things that could have caused that other than the heads.
