Drag radial DOT slick help #910032
01/20/11 11:17 PM
01/20/11 11:17 PM
South Dakota
Mirada440 Offline OP
South Dakota
I need some new rear tires and i want to swith over to a DOT tire for the street car class, my car currently has a set of 29.5 10.50 15 M/T slicks on it and i want to stay with that same size or close to it. Im having trouble finding DOTs in the same size and im not sure what size that it would be in a radial? Any help would be great
Re: Drag radial DOT slick help [Re: Mirada440] #910033
01/21/11 03:44 AM
01/21/11 03:44 AM
South East VA
Joel71 Offline
Joel71  Offline
South East VA
Either a 295/65-15 or a 315/60-15 would be close. Neither is exactly the same...first is not as wide and second one is a little wider according to M/T's drag radial specs. Both are a small amount taller.
Re: Drag radial DOT slick help [Re: Joel71] #910034
01/21/11 11:34 AM
01/21/11 11:34 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IMO, the "295" size the person above mentioned is going to be your closest match. They're about 29.5" tall w/ a 10" tread width, IIRC.
Re: Drag radial DOT slick help [Re: BradH] #910035
01/21/11 12:29 PM
01/21/11 12:29 PM
South Dakota
South Dakota
10 wide would work, i cant really go any wider then a 10.5 cause right now they are really close to rubbing, Any brands better then others? Will they hook has good as slicks?
Re: Drag radial DOT slick help [Re: Mirada440] #910036
01/21/11 12:34 PM
01/21/11 12:34 PM
BradH Offline
BradH  Offline
ET Street Radials (actually, any radial slicks or DOT-legal race tires) are more sensitive to chassis setup & tuning than traditional bias-ply slicks. However, they can run as fast, even faster, when the combination is sorted out. I've gone 10.5s @ 126 w/ 1.45 60-fts on the smaller 275/60R15 size. You don't give any current performance #s, so it's hard to say if that's a good indicator or not.
