Re: Trap RPM help [Re: sjs64polara] #909887
01/23/11 11:15 AM
01/23/11 11:15 AM
Wisconsin
sjs64polara Offline OP
Wisconsin
OK, I had to think about it for a while. Sounds like we have two different theories here, simply stated 5%-10% over max hp rpm and screaming it.
I know cars that turn left keep the rpms way past max to keep wheel speed high. If they ran less rpm the car wouldn’t accelerate as fast coming out of the turns.
So why two different theories used in drag racing
Re: Trap RPM help [Re: sjs64polara] #909888
01/23/11 11:36 AM
01/23/11 11:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its called trial and error to find out what your
set up wants
Re: Trap RPM help [Re: MR_P_BODY] #909889
01/23/11 12:01 PM
01/23/11 12:01 PM
Wisconsin
Wisconsin
set up wants
Lots of those happening in my pits
OK, one more variable to record in my log and test
Re: Trap RPM help [Re: sjs64polara] #909890
01/23/11 12:09 PM
01/23/11 12:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I can tell you that with my N/SS 63 Dodge running past peak did nothing except turn the engine higher. I ran a 4.56 then a 4.88 then a 4.10. It ran within .05 with all three. Your combo may be different. My bet is the more torque you have under the curve, the less the effect of over gearing has. I will test this theory this Summer.
Doug
Re: Trap RPM help [Re: sjs64polara] #909891
01/23/11 12:21 PM
01/23/11 12:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
set up wants
From my testing I have seen a wider LSA as in 112
VS a 108 the wider LSA has a wider power band and
is more tolerant to rpm ... I dont see my car do
much in ET on RPM changes(unless its ALOT of RPM)
