broken engine repair help needed in Phoenix area #909850
01/20/11 08:24 PM
01/20/11 08:24 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I built a 440 for a friend in Phoenix 4-5 years ago. It wiped the cam recently and needs repair.
It has Eddy heads,comp hydraulic,K.B. pistons,and a factory cross ram. I don't know if it damaged anything else besides the #7 intake lobe,still has normal oil pressure. Anybody know where he could take it to be repaired? I'm in Michigan so it's a little tough for me to do it.
Doug
Re: broken engine repair help needed in Phoenix area [Re: dvw] #909851
01/20/11 08:45 PM
01/20/11 08:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
It may be true any good machine shop can work on Mopars just as good as chevy's & fords. Just make sure you take your race engines to a shop that works only on race engines.If your local shop works on everything from tractors to lawn mowers,guess what the quality of work you will be. I found this out the hard way!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: broken engine repair help needed in Phoenix area [Re: MRMOPAR622] #909852
01/20/11 11:18 PM
01/20/11 11:18 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
dvw,
Are you looking for a machine shop, or a place to take the whole car, for a diagnosis and repair? If your buddy doesn't want to wrench on it, I would suggest Magoo's Automotive, 623-362-1765. John Schurr, is the owner, and runs the shop out of his back yard in a spacious, well-equipped shop. He was a chrysler line mechanic for many years, and races a Bigblock 67 Valiant in the 10's. He has worked on my Daily drivers for over 10 years, very fair, and reliable.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: broken engine repair help needed in Phoenix area [Re: MoparBilly] #909853
01/20/11 11:59 PM
01/20/11 11:59 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'll throw Comp Chassis out there as a possibility. I was very pleased with what those guys did for me.
Re: broken engine repair help needed in Phoenix area [Re: dvw] #909854
01/21/11 12:20 AM
01/21/11 12:20 AM
SC304 Offline
SC304  Offline
Doug call me.
I may have a plan?
Clyde
