Re: Converter bolt question Lock tite?????
[Re: Quicktree]
#909714
01/20/11 08:46 PM
01/20/11 08:46 PM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
Loctite blue here. I get them as tight as I can.
same here
I 3rd that
[Re: Chris2581]
#909716
01/20/11 09:47 PM
01/20/11 09:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i think i use green is that one of the colors?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#909717
01/20/11 10:16 PM
01/20/11 10:16 PM
If your using green, you'll need heat to get them off. That's permanent loc-tite. I like the red and really crank down on the bolts with a 12 point open end wrench and put a long bar over the end of the wrench for better leverage.
[Re: maximum entropy]
#909720
01/20/11 10:48 PM
01/20/11 10:48 PM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
how did we get into mowing grass
i think the answer is obvious.
Yeah .. obvious ?
A member by the name of Twin Turbo Mower answers this Q ...and I ask HIM if he uses this stuff on his MOWER BLADES.
A reasonable Q ....I think so.
[Re: BeEtLeJuIcE !]
#909721
01/20/11 10:49 PM
01/20/11 10:49 PM
Quicktree
Yeah .. obvious ?
[Re: Quicktree]
#909723
01/20/11 11:04 PM
01/20/11 11:04 PM
BeEtLeJuIcE !
Florida STAYcation
Yeah .. obvious ?
CrAzY you ? ... oh-tay ! ..
[Re: DemonDust]
#909725
01/20/11 11:34 PM
01/20/11 11:34 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Wow! So everyone uses loctite, just depends what color you want to use... I think I'll use blue, in case I need to take it out.... Thanks for all the answers, and if I need any lawn mower tech I know where to come as well
[Re: emarine01]
#909727
01/21/11 03:14 AM
01/21/11 03:14 AM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
Just for the record 271 red tastes the best
It taste like somthing the dentist uses.
[Re: Crizila]
#909730
01/21/11 12:30 PM
01/21/11 12:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
use red. If they are a little snug when you take them out then just warm the bolt(I use a little propane torch) and they come right out. You don't need to heat the hell out of it, just warm it up.
BTW, if you ever take apart a car(any daily driver-foreign or domestic) you will see loctite residue on just about every fastener.
MB
Thats because they are less concerned with you taking it apart than with leaks.
The conv bolts you buy from MP has a bit of lock- tite on each and I dont rememmber what color it is, might be blue or red... I hit them with a impact through the starter area(not hammering on them)
