Re: Converter bolt question Lock tite????? [Re: Quicktree] #909714
01/20/11 08:46 PM
01/20/11 08:46 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
Loctite blue here. I get them as tight as I can.
same here
I 3rd that
Re: Converter bolt question Lock tite????? [Re: DemonDust] #909715
01/20/11 09:37 PM
01/20/11 09:37 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use red.
Nautilus Racing-
Re: Converter bolt question Lock tite????? [Re: Chris2581] #909716
01/20/11 09:47 PM
01/20/11 09:47 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i think i use green is that one of the colors?
Re: Converter bolt question Lock tite????? [Re: sixpackgut] #909717
01/20/11 10:16 PM
01/20/11 10:16 PM
If your using green, you'll need heat to get them off. That's permanent loc-tite.
I like the red and really crank down on the bolts with a 12 point open end wrench and put a long bar over the end of the wrench for better leverage.
Re: Converter bolt question Lock tite????? #909718
01/20/11 10:26 PM
01/20/11 10:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
that explains why i'm always buying propane
Re: Converter bolt question Lock tite????? [Re: DemonDust] #909719
01/20/11 10:35 PM
01/20/11 10:35 PM
Az
Crizila Offline
Crizila  Offline
Az
BLUE.
Fastest 300
Re: Converter bolt question Lock tite????? [Re: maximum entropy] #909720
01/20/11 10:48 PM
01/20/11 10:48 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
how did we get into mowing grass
i think the answer is obvious.
Yeah .. obvious ?
A member by the name of Twin Turbo Mower answers this Q ...and I ask HIM if he uses this stuff on his MOWER BLADES.
A reasonable Q ....I think so.
Re: Converter bolt question Lock tite????? [Re: dOc !] #909721
01/20/11 10:49 PM
01/20/11 10:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Yeah .. obvious ?
Re: Converter bolt question Lock tite????? #909722
01/20/11 10:53 PM
01/20/11 10:53 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
...then hit with a hammer a couple times.
If you like drag racing, support your local track.
Re: Converter bolt question Lock tite????? [Re: Quicktree] #909723
01/20/11 11:04 PM
01/20/11 11:04 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Yeah .. obvious ?
CrAzY you ? ... oh-tay ! ..
Re: Converter bolt question Lock tite????? [Re: sixpackgut] #909724
01/20/11 11:34 PM
01/20/11 11:34 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you are using green (290) According to the loctite reps that came to the steel mill you may want to change next time. Every rep that came in recommended 271 for converter bolts. Here's a link for 290 (green)
http://www.loctiteproducts.com/p/t_lkr_green/overview/Loctite-Threadlocker-Green-290.htm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Converter bolt question Lock tite????? [Re: DemonDust] #909725
01/20/11 11:34 PM
01/20/11 11:34 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Wow! So everyone uses loctite, just depends what color you want to use...
I think I'll use blue, in case I need to take it out....
Thanks for all the answers, and if I need any lawn mower tech I know where to come as well
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Converter bolt question Lock tite????? [Re: DemonDust] #909726
01/21/11 02:12 AM
01/21/11 02:12 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Just for the record 271 red tastes the best
Re: Converter bolt question Lock tite????? [Re: emarine01] #909727
01/21/11 03:14 AM
01/21/11 03:14 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
It taste like somthing the dentist uses.
Re: Converter bolt question Lock tite????? [Re: Twin Turbo Mower] #909728
01/21/11 08:51 AM
01/21/11 08:51 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
use red. If they are a little snug when you take them out then just warm the bolt(I use a little propane torch) and they come right out. You don't need to heat the hell out of it, just warm it up.
BTW, if you ever take apart a car(any daily driver-foreign or domestic) you will see loctite residue on just about every fastener.
MB
Re: Converter bolt question Lock tite????? [Re: HPMike] #909729
01/21/11 11:53 AM
01/21/11 11:53 AM
Az
Crizila Offline
Crizila  Offline
Az
MB
Thats because they are less concerned with you taking it apart than with leaks.
Fastest 300
Re: Converter bolt question Lock tite????? [Re: Crizila] #909730
01/21/11 12:30 PM
01/21/11 12:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
MB
The conv bolts you buy from MP has a bit of lock-
tite on each and I dont rememmber what color it is,
might be blue or red... I hit them with a impact
through the starter area(not hammering on them)
Re: Converter bolt question Lock tite????? [Re: Quicksilver440] #909731
01/21/11 06:33 PM
01/21/11 06:33 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I use Blue....when I have used red, I have sometimes had to heat the bolts with a propane torch to break them free.
How much torque were you applying to the bolts before the use of heat?
If red was holding that tight the bolt heads would break off before the threads came loose.
Re: Converter bolt question Lock tite????? [Re: John_Kunkel] #909732
01/21/11 07:21 PM
01/21/11 07:21 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
BLUE for me.
Before I apply the LockTite, I spray the threads with carb cleaner to make sure there is no oil residue to weaken the bond.
Re: Converter bolt question Lock tite????? [Re: B5 Bee] #909733
01/21/11 07:30 PM
01/21/11 07:30 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I don't know where people got the idea that Loctite is "permanent". I use a lot of Loctite and have never/ever had a problem removing a fastener.
Race cars are harsh environments, just like Harleys snd Diesel vehicles. It's just an extra measure of protection.
MB
