Torsion bar??? #909395
01/20/11 01:39 PM
01/20/11 01:39 PM
Odessa, Tejas
ChallengerRTSE Offline OP
Odessa, Tejas
Are torsion bars specific to there location during install, ie left or right? I haven't installed torsion bars in years but something in the back of my mind says there is a rightside torsion bar and a leftside one as well. My new bars aren't marked either way.
Re: Torsion bar??? [Re: ChallengerRTSE] #909396
01/20/11 01:42 PM
01/20/11 01:42 PM
md
mopars4ever Offline
mopars4ever  Offline
md
check on the end of the bar, IIRC the numbers should have a L for left side and R for right. that was with factory t bars. aftermarket bars may be different.
Re: Torsion bar??? [Re: mopars4ever] #909397
01/20/11 01:50 PM
01/20/11 01:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Torsion bar??? [Re: JohnRR] #909398
01/20/11 01:51 PM
01/20/11 01:51 PM
Odessa, Tejas
Odessa, Tejas
Thats what I was thinking. I guess I will have to get with the manufactor.
Re: Torsion bar??? [Re: ChallengerRTSE] #909399
01/20/11 01:52 PM
01/20/11 01:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are they numbered ? also are they different size , one bigger diameter than the other ? If so the larger goes on the left .
Re: Torsion bar??? [Re: JohnRR] #909400
01/20/11 02:04 PM
01/20/11 02:04 PM
Odessa, Tejas
Odessa, Tejas
Yes they have a part number, the same. They should be the same size but I will check them.
Re: Torsion bar??? [Re: ChallengerRTSE] #909401
01/20/11 02:35 PM
01/20/11 02:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If that's the case then it may not matter what side , I guess a call to the maker is in order.
Re: Torsion bar??? [Re: JohnRR] #909402
01/20/11 02:44 PM
01/20/11 02:44 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
stockers have a right and left
when I got my just suspension bars I called since there was no designation. They told me they can go in any way, just keep them in that same orientation if i ever remove them after that.
Re: Torsion bar??? [Re: JohnRR] #909403
01/20/11 02:50 PM
01/20/11 02:50 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
DIFFERENT sizes?
Uhhh... no, they should be the same size for both. The ONLY time you might want different sized T bars would be on a circle track car, and even then you would want the larger bar on the right. What are you thinking?
Re: Torsion bar??? [Re: Kern Dog] #909404
01/20/11 05:30 PM
01/20/11 05:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
DIFFERENT sizes?
WRONG , depends on the car, B/E body with the factory a HEMI suspension , one T Bar is bigger than the other , I may have the sides crossed , but I know what I am talking about ....
Re: Torsion bar??? [Re: JohnRR] #909405
01/20/11 05:49 PM
01/20/11 05:49 PM
Andrewh Offline
Andrewh  Offline
as I recall over 1 inch does not matter on sides if they are new.
smaller you do need to know.
Never heard of different size t-bars. I know rear springs can be different.
Re: Torsion bar??? [Re: ChallengerRTSE] #909406
01/20/11 09:29 PM
01/20/11 09:29 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Whats the numbers you see, Like said, the bigger bars over 1" are the same for both sides. mike
Re: Torsion bar??? [Re: Sport440] #909407
01/21/11 03:43 PM
01/21/11 03:43 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Agreed. If numbered, generally speaking, the odd numbered part goes on the driver's side of the car, the even numbered part goes on the right side of the car...
Front to rear doesn't matter either for T-bars, generally, as the twist direction will be the same.
However, it's preferable to have the part number on the end of the bar to the rear, so it can be looked at later while it's installed in the car. (In case you're an Alzheimer's goof, like me )
Re: Torsion bar??? [Re: ChallengerRTSE] #909408
01/22/11 11:33 AM
01/22/11 11:33 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Bars are left and right due to the clocking of the hexes. On some of the aftermarket bars including many of the larger ones from Mopar Performance, California Suspension (long out of business) and others, the hex flats are either parallel front to rear or 30 degrees clocked. These bars can be swapped left to right.
With proper clocking, the t-bar adjuster will be somewhere near the middle of its range when the car is at ride hieght.
