Re: Torsion bar???
[Re: ChallengerRTSE]
#909399
01/20/11 01:52 PM
01/20/11 01:52 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
Thats what I was thinking. I guess I will have to get with the manufactor. Thanks
Are they numbered ? also are they different size , one bigger diameter than the other ? If so the larger goes on the left .
Re: Torsion bar???
[Re: JohnRR]
#909403
01/20/11 02:50 PM
01/20/11 02:50 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
DIFFERENT sizes? Uhhh... no, they should be the same size for both. The ONLY time you might want different sized T bars would be on a circle track car, and even then you would want the larger bar on the right. What are you thinking?
Re: Torsion bar???
[Re: Kern Dog]
#909404
01/20/11 05:30 PM
01/20/11 05:30 PM
JohnRR
WRONG , depends on the car, B/E body with the factory a HEMI suspension , one T Bar is bigger than the other , I may have the sides crossed , but I know what I am talking about ....
Re: Torsion bar???
[Re: Sport440]
#909407
01/21/11 03:43 PM
01/21/11 03:43 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Whats the numbers you see, Like said, the bigger bars over 1" are the same for both sides. mike
Agreed. If numbered, generally speaking, the odd numbered part goes on the driver's side of the car, the even numbered part goes on the right side of the car...
Front to rear doesn't matter either for T-bars, generally, as the twist direction will be the same. However, it's preferable to have the part number on the end of the bar to the rear, so it can be looked at later while it's installed in the car. (In case you're an Alzheimer's goof, like me )
