Thanks To John Cope.... CRT
#908975
01/19/11 10:50 PM
01/19/11 10:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I needed a new input shaft and support for my 518 to change it to a 727 input so I can run one of my race converters in my Rampage. John asked if it was the big or small mid shaft(front of the mid shaft)... well it had the small front... of course its the harder to find part .... well he came through for me... he sent me a new input shaft that fits the small mid shaft with a new pump and support.... Thanks John now I have everything needed to make a go fast OD trans without lock up for my drag week car
Re: Thanks To John Cope.... CRT
[Re: sam64]
#908977
01/20/11 12:12 AM
01/20/11 12:12 AM
MR_P_BODY
maybe some of us okies will get to meet you drag week in tulsa,they say its coming through here.
So I hear... hopefully I can get mine done for it... me and my buddy were talking price to head out there with one or both rides and it looks like it would cost us about $1300 each if we both register but less if I ride shotgun again... I'm trying to get mine done but still have a TON of work ahead of me
[Re: MR_P_BODY]
#908978
01/20/11 12:31 AM
01/20/11 12:31 AM
Posts: 2,110 toledo, ohio
plasticfantastic
toledo, ohio
get it done and have him ride shotgun!! Wish I was closer, be there helping/learning, on a side note I may have a pair of doors for you.
[Re: MR_P_BODY]
#908981
01/20/11 01:48 AM
01/20/11 01:48 AM
plasticfantastic
toledo, ohio
I can use both door panels(interior).... Doug is this from a L body(2 door Omni/Horizon) or a Rampage I have a broken piece of trim that is Rampage only
its a rampage... Word I'm getting is the doors may be trashed, I'm going to look at it this weekend. what trim do you need?
[Re: MR_P_BODY]
#908984
01/20/11 04:26 PM
01/20/11 04:26 PM
Posts: 16,928 NC
440Jim
NC
John is the trans man, good guy.
I have a A518, non-lockup, hydraulic (RH), and this may be in my future, so
What are the approximate dimensions that identify the "small" or "big" shaft?
[Re: 440Jim]
#908989
01/21/11 01:23 PM
01/21/11 01:23 PM
Posts: 16,928 NC
440Jim
NC
Tomorrow I will see if my 727 converter fits the input/pump/reaction support.
My A518 (non-lockup) pump/reaction support/input shaft slide right into a 727 converter. The setup I have has 24 splines on the input shaft (and no lockup through hole). And the tip of the input shaft has splines all the way to the end (727 style).
I believe the lockup shafts have 23 splines on the input shaft and a machined smooth tip (pic attached). And as Raff mentioned, the lockup reaction support has different fluid holes to go with the lockup input features.
And these are some other 518 notes I have kept from other posts:Quote:
A 2-wire connector trans has OD only, no lockup.
A 3-wire trans (RH) has both lockup and OD.
The 8-wire trans (RE) has an electronic governor and lockup converter. It is electronic and only used with EFI.
'95 and earlier are designated RH and are hydraulically controlled except for the OD and converter. '96 and later are designated RE and are electronically controlled. The '95 and earlier is the best choice for retrofitting.
[Re: 440Jim]
#908991
01/21/11 09:47 PM
01/21/11 09:47 PM
MR_P_BODY
Here is somthing I saved on my computer showing the various input shafts.
Raff, Did your original A518 lockup input shaft have the smooth tip, and the replacement John Cope got for you look like the 727 shaft (splines to the tip)?
Jim I dont recall if it was smooth but it did had the hole in the center of the shaft... the one I got from Cope looks like the middle one but no groove at the front... come to think of it I WILL try my converter on this set up just to make sure it fits
[Re: CRT]
#908992
01/21/11 09:51 PM
01/21/11 09:51 PM
Posts: 30,460 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Glad I can help ya with that hard to find part.
HOW about a goose-neck PB shifter ?
