Re: 73 Bucket seats in a 68 B-Body, seat track question
[Re: DANA60]
#908854
01/19/11 07:01 PM
01/19/11 07:01 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
The 70 B body will be close.
I would think the 70 Seat tracks would fix this , the 70 and the 68 share the same floorpan and the bottom of his newer seat should be the same as a 70 seat bottom in basic shape and mounting .
[Re: mkvien]
#908858
03/29/11 05:31 PM
03/29/11 05:31 PM
Posts: 70 MN
mkvien
MN
Got them installed, they fit pretty well. Couple of issues, one related to my car and one to the repop mounts I bought.
I wonder if the steering column or something is a different length on the 68 vs the 70 B-bodies. I am not a tall man, 5'9", but in the factory holes (I used 2 from the original bench seat, and 2 new ones that I drilled and reinforced) I was almost up against the steering wheel and knees bent with the seat slid all the way back. I welded the other holes shut and moved the seats back the 2.5" I coule without the rear of the tracks getting into the slope of the rear footwell.
The mounts look like nice pieces, they fit and slide well. The factory paint is crappy, I could scrape it off with my fingernail. Also, the wires the connect the 2 seat tracks are about 1.5" too long so I had to cut and re-bend the to make them work.
Other than that, they are in and if you need a set they are probably worth the $325 I paid for the pair.
