Need a Master Cylinder rebuild " New Question"
#90870
07/19/08 05:06 PM
07/19/08 05:06 PM
Need a orginal 70 Challenger Master Cylinder rebuild. Does anybody know theses guys? http://www.applehydraulics.com/?
Re: Need a Master Cylinder rebuild
[Re: LYNCHROAD69.5]
#90872
07/20/08 11:14 PM
07/20/08 11:14 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
Don't know them but try these guys. http://www.whitepost.com/brake.html
If it's a '70 E body disc brake master cylinder don't even think about sending it to White Post. They use the wrong kit to rebuild and it won't work!!!! I've used Brake and Equipment Warehouse in Minneapolis and they have done well for me and know these "'9171" MC's well. Also Pete's restoration, he is a member here, was restoring the '70 disc brake E body cylinders correctly.
[Re: Mastershake340]
#90873
07/20/08 11:29 PM
07/20/08 11:29 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I still have some of the rebuild kits for them and a local place thet will put a SS sleve in them
NS1AAR
#90874
07/21/08 06:53 AM
07/21/08 06:53 AM
I found B&E warehouse on the web but what about Petes? Any contact info?
#90879
07/21/08 10:44 PM
07/21/08 10:44 PM
Posts: 5,268 NY
70440+6bbl
NY
Yup, they will tell you that the kit they use is correct and trust me, it is not!!! Your front brakes will be applied as soon as you bolt it in place on the booster. The pistons are too long. I paid WP around $200. for the rebuild/sleeve and then bought the correct kit from ns1aar which corrected my problem . Now, I have over $300. into my master plus the cost of the core, which was not cheap to say the least
[Re: 70440+6bbl]
#90880
07/23/08 08:10 PM
07/23/08 08:10 PM
Thanks for all the suggestions and now another question. What should I be looking at Brass sleeves or stainless steels? What are the pros and cons?
