Need a Master Cylinder rebuild " New Question" #90870
07/19/08 05:06 PM
07/19/08 05:06 PM
Anonymous OP
Anonymous OP
Need a orginal 70 Challenger Master Cylinder rebuild. Does anybody know theses guys?
http://www.applehydraulics.com/
Re: Need a Master Cylinder rebuild #90871
07/20/08 08:58 PM
07/20/08 08:58 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
Don't know them but try these guys.
http://www.whitepost.com/brake.html
Re: Need a Master Cylinder rebuild [Re: LYNCHROAD69.5] #90872
07/20/08 11:14 PM
07/20/08 11:14 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
If it's a '70 E body disc brake master cylinder don't even think about sending it to White Post. They use the wrong kit to rebuild and it won't work!!!!
I've used Brake and Equipment Warehouse in Minneapolis and they have done well for me and know these "'9171" MC's well. Also Pete's restoration, he is a member here, was restoring the '70 disc brake E body cylinders correctly.
Re: Need a Master Cylinder rebuild [Re: Mastershake340] #90873
07/20/08 11:29 PM
07/20/08 11:29 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I still have some of the rebuild kits for them and a local place thet will put a SS sleve in them
NS1AAR
Re: Need a Master Cylinder rebuild [Re: Mastershake340] #90874
07/21/08 06:53 AM
07/21/08 06:53 AM
Anonymous OP
Anonymous OP
I found B&E warehouse on the web but what about Petes? Any contact info?
Re: Need a Master Cylinder rebuild #90875
07/21/08 03:26 PM
07/21/08 03:26 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Re: Need a Master Cylinder rebuild [Re: TrueTripleX] #90876
07/21/08 03:32 PM
07/21/08 03:32 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I have not looked at any of those links ... but how about a stainless linered rebuilt MC for a older Dodge truck chassis ?
Re: Need a Master Cylinder rebuild #90877
07/21/08 06:44 PM
07/21/08 06:44 PM
Crook County, ILL
Crook County, ILL
Pete is a member here, he gave contact info in this thread:
https://board.moparts.org/ubbthreads/show...rue#Post4545795
Re: Need a Master Cylinder rebuild [Re: Mastershake340] #90878
07/21/08 09:54 PM
07/21/08 09:54 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
This is were I have mine done www.resleeve.com .They do Stainless sleeves
NS1AAR
Re: Need a Master Cylinder rebuild [Re: Mastershake340] #90879
07/21/08 10:44 PM
07/21/08 10:44 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Yup, they will tell you that the kit they use is correct and trust me, it is not!!! Your front brakes will be applied as soon as you bolt it in place on the booster. The pistons are too long. I paid WP around $200. for the rebuild/sleeve and then bought the correct kit from ns1aar which corrected my problem . Now, I have over $300. into my master plus the cost of the core, which was not cheap to say the least
Re: Need a Master Cylinder rebuild [Re: 70440+6bbl] #90880
07/23/08 08:10 PM
07/23/08 08:10 PM
Anonymous OP
Anonymous OP
Thanks for all the suggestions and now another question. What should I be looking at Brass sleeves or stainless steels? What are the pros and cons?
