e-body to a-body exhaust manifolds #90859
07/19/08 04:12 PM
07/19/08 04:12 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
will 72' 340 challenger exhaust manifolds have enough clearance for a 71' 318 dart? thanks
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: e-body to a-body exhaust manifolds [Re: mopars_1] #90860
07/19/08 09:32 PM
07/19/08 09:32 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
No
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: e-body to a-body exhaust manifolds [Re: 69L78Nova] #90861
07/19/08 09:50 PM
07/19/08 09:50 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
How come? I have early 340 HP manifolds in my 71 Duster. The 72 Hp manifolds have a center dump passenger side. Where would you have a problem?
Re: e-body to a-body exhaust manifolds [Re: dmerc] #90862
07/19/08 10:17 PM
07/19/08 10:17 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
the pass side manifold looks identical, but I was just curious to if the drivers side would fit
1937 Plymouth PT50
Re: e-body to a-body exhaust manifolds [Re: mopars_1] #90863
07/19/08 10:39 PM
07/19/08 10:39 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
EDIT I made a mistake
1970
1973 (a 72 has the larger outlet identical to the 70)
Why did the 70 340 E and A's have the same manifolds but the 71 and up E bodies were different on the drivers side than the A bodies?
Re: e-body to a-body exhaust manifolds [Re: mopars_1] #90864
07/19/08 11:20 PM
07/19/08 11:20 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
71-74 left e-body 340-360 exhaust manifolds will not fit an a-body. It is a short necked ball joint
connection style manifold that will not clear the a-body steering column. The right side will fit as
the 623 casting was used for A,B,and E body 340-360 applications. If 340-360 manifolds are being used on a 318 , 318 manifold gaskets must be used
or you will have an exhaust leak as the ports on the manifolds are larger than the 318 head ports.
Re: e-body to a-body exhaust manifolds [Re: Tom Swope] #90865
07/20/08 12:26 AM
07/20/08 12:26 AM
N
noisydart Offline
super gas
noisydart  Offline
super gas
N
Tom Swope is the man- the expert! He has Accurate
LTD and doesn't want to toot his own horn. I bought
some big block 440-A body conversion manifolds
from him maybe 4 yrs. ago and they were perfect
and worth every penny. He probably knows more about mopar exhaust systems than anyone else
on this site!
