Who is the Carter carb guru? #907882
01/18/11 07:24 AM
01/18/11 07:24 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Who knows the CFM rating for the muscle era Carter carburetors? I have an AVS from a 71 Chrysler 300 with a 440 and a 727. The FSM tells nothing. I also wondered the ratings of the 68-71 340 and the 67-71 383. Who has the info? Thanks.
Re: Who is the Carter carb guru? [Re: Kern Dog] #907883
01/18/11 08:25 AM
01/18/11 08:25 AM
see the "AFB QUESTION" thread further down. QuickD100 posted CFM's for the diff venturi sizes which'd very likely be the same for OE type AFB's/AVS's. EDIT those are base plate throttle bore dia's. I just checked my 4131S AFB which is listed for a '66 440 & it's 1&7/16" & 1&9/16" which'd be (750) but I think Carters' published specs are a bit happy
Re: Who is the Carter carb guru? [Re: RapidRobert] #907884
01/18/11 10:47 AM
01/18/11 10:47 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Who is the Carter carb guru? [Re: RapidRobert] #907885
01/18/11 11:29 AM
01/18/11 11:29 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
IIRC the Carter AFB's were rated at a different specification than Holleys. Different "inches of water". Or so I've heard.
Re: Who is the Carter carb guru? [Re: Kern Dog] #907886
01/18/11 02:57 PM
01/18/11 02:57 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
1971 440 avs
4966 625 cfm lp
4967 750 cfm hp
4568 750 cfm hp
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Who is the Carter carb guru? [Re: RapidRobert] #907887
01/18/11 03:14 PM
01/18/11 03:14 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I posted the venturi diameters for their carbs, the throttle plate diameters are not the same as the venturi diameters, case in point.
The 500's and 625's both use 1-7/16 promary throttle plates, the secondaries throttle plates measure 1-11/16 on both.
The info comes out of Dave Emanuel's "Super Tuning and Modifying Carter Carburetors". Dave
Re: Who is the Carter carb guru? [Re: quickd100] #907888
01/18/11 05:03 PM
01/18/11 05:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, but where did HE get the info? The old Mopar Performance Clinic literature had vastly lower numbers than those usually quoted.
Who is one to believe?
Re: Who is the Carter carb guru? [Re: quickd100] #907889
01/18/11 05:05 PM
01/18/11 05:05 PM
Dave when I measured my throttle bores & got the 1&7/16/1&9/16 that's what made me think that it was supposed to be the throttle bores & not the venturi's. I stand corrected
Re: Who is the Carter carb guru? [Re: RapidRobert] #907890
01/18/11 07:53 PM
01/18/11 07:53 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
IIRC the quick way to know the size is if the plates are all the same size, it is a small carb, if they are different then it is the bigger one.
Re: Who is the Carter carb guru? [Re: SomeCarGuy] #907891
01/18/11 08:40 PM
01/18/11 08:40 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't think this statement accurately captures the different sizes. The large AFB will have 1 11/16" primary and secondary throttle plates.
1 7/16 & 1/9/16 is a small AFB. I don't think there was anything from 66 that had the large AFB.
Re: Who is the Carter carb guru? [Re: John_Kunkel] #907892
01/18/11 09:32 PM
01/18/11 09:32 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The old Direct Connection (?)clinic literature says something like 650 for the large AVS (440 HP), and 550(?) for the smaller AVS (340, 383 & non-hp 440). I lost the old article link in a computer crash.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Who is the Carter carb guru? [Re: BSB67] #907893
01/18/11 09:42 PM
01/18/11 09:42 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I realize that carter and holley rate their carbs differently but how else do you define their sizes? I just use the companies listed sizes and call it good.Dave
Re: Who is the Carter carb guru? [Re: quickd100] #907894
01/18/11 09:57 PM
01/18/11 09:57 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Are we all talking about the same thing? AVS vs. AFB
Re: Who is the Carter carb guru? [Re: SomeCarGuy] #907895
01/18/11 11:21 PM
01/18/11 11:21 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
More specifically...... I have the original carburetor from a 71 Chrysler 300, a Carter AVS, and I wanted to know if anyone had the CFM size. I guess with an apples to oranges definition of flow rate, it must be impossible to tell.
Re: Who is the Carter carb guru? [Re: SomeCarGuy] #907896
01/18/11 11:33 PM
01/18/11 11:33 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
on a carter avs 67-71 except for the 1971 4966
which is 625cfm all 440 hp 67 -71 four barrels are the same size. from 1967 to 1970 carter avs 383 and 340s are 625 cfm 2 are small and 2are big
67 =71 440 are 4 big ones - 750 cfm
Re: Who is the Carter carb guru? [Re: 440beep] #907897
01/19/11 12:36 AM
01/19/11 12:36 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
No AVS in 67.
Re: Who is the Carter carb guru? [Re: 62maxwgn] #907898
01/19/11 12:46 AM
01/19/11 12:46 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
No AVS in 67.
1968 oops
Re: Who is the Carter carb guru? [Re: 440beep] #907899
01/19/11 01:40 AM
01/19/11 01:40 AM
North Central Florida
E
eightlitermopar Offline
E
No AVS in 67.
1968 oops
THREAD HIJACK!!!
So I have a a CARTER AVS carb 4968 S from a 1970 or 1971 440...So this is a 750? I always thought it was a 625?
just to clarify....
eight
Mopar or no car
