Re: Who is the Carter carb guru?
[Re: Kern Dog]
#907883
01/18/11 08:25 AM
01/18/11 08:25 AM
RapidRobert
see the "AFB QUESTION" thread further down. QuickD100 posted CFM's for the diff venturi sizes which'd very likely be the same for OE type AFB's/AVS's. EDIT those are base plate throttle bore dia's. I just checked my 4131S AFB which is listed for a '66 440 & it's 1&7/16" & 1&9/16" which'd be (750) but I think Carters' published specs are a bit happy
[Re: RapidRobert]
#907885
01/18/11 11:29 AM
01/18/11 11:29 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
IIRC the Carter AFB's were rated at a different specification than Holleys. Different "inches of water". Or so I've heard.
[Re: RapidRobert]
#907887
01/18/11 03:14 PM
01/18/11 03:14 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I posted the venturi diameters for their carbs, the throttle plate diameters are not the same as the venturi diameters, case in point. The 500's and 625's both use 1-7/16 promary throttle plates, the secondaries throttle plates measure 1-11/16 on both. The info comes out of Dave Emanuel's "Super Tuning and Modifying Carter Carburetors". Dave
[Re: quickd100]
#907889
01/18/11 05:05 PM
01/18/11 05:05 PM
RapidRobert
Dave when I measured my throttle bores & got the 1&7/16/1&9/16 that's what made me think that it was supposed to be the throttle bores & not the venturi's. I stand corrected
[Re: SomeCarGuy]
#907891
01/18/11 08:40 PM
01/18/11 08:40 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
IIRC the quick way to know the size is if the plates are all the same size, it is a small carb, if they are different then it is the bigger one.
I don't think this statement accurately captures the different sizes. The large AFB will have 1 11/16" primary and secondary throttle plates.
1 7/16 & 1/9/16 is a small AFB. I don't think there was anything from 66 that had the large AFB.
[Re: SomeCarGuy]
#907896
01/18/11 11:33 PM
01/18/11 11:33 PM
Posts: 1,183 eganville ont
440beep
eganville ont
on a carter avs 67-71 except for the 1971 4966 which is 625cfm all 440 hp 67 -71 four barrels are the same size. from 1967 to 1970 carter avs 383 and 340s are 625 cfm 2 are small and 2are big
67 =71 440 are 4 big ones - 750 cfm
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: 440beep]
#907897
01/19/11 12:36 AM
01/19/11 12:36 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
No AVS in 67.
