Re: w-5 guys piston talk !
[Re: RAY1969CARS]
#907843
01/19/11 12:42 AM
01/19/11 12:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
yes stock stoke i called ross at lunch they say thay wont work 1 the 99628s but i think with a lil milling they may ??? a custom set is like a 1000 !!! wow! the 99628s at muscle motors are 609.00 ??? what to do ?!
Check with Diamond I had them change the pin height on my pistons($35) and had them open the intake valve relief ($8) to fit my 2.08 intakes on my W-5s... so for a added total of $43 I got what I needed
[Re: Performance Only]
#907846
01/19/11 08:38 AM
01/19/11 08:38 AM
MR_P_BODY
$8.00 dollars to open the intake valve reliefs on all 8 pistons? so 1.00 dollar a piece?
That is correct
[Re: RAY1969CARS]
#907847
01/19/11 08:41 AM
01/19/11 08:41 AM
MR_P_BODY
how mush did you move the pin up ???
I dont have the paper here in the house but its up into the oil ring land
[Re: MR_P_BODY]
#907848
01/19/11 01:26 PM
01/19/11 01:26 PM
Posts: 2,128 sweden
sshemi
sweden
My last stroker sb had NO custom diamond pistons with no extra work for reliefing the valves on my 2.08 w5s
[Re: sshemi]
#907849
01/19/11 05:06 PM
01/19/11 05:06 PM
Guitar Jones
My W5's are small chamber heads cut .050 for a 47cc chamber. I used a flat top piston .011 out of the hole with a .038 head gasket, worked out to like 12.7 IIRC. I guess that doesn't really help you but you can get away with as little as .027 piston to head clearance. My engine has beed 7500 many times with no problems.
[Re: emarine01]
#907851
01/19/11 05:20 PM
01/19/11 05:20 PM
Guitar Jones
A 47cc chamber, .011 outa the hole flat top with a .038 gasket = 12.7 to 1 compression
Yeah, I think there was about 7cc of valve relief, it's .020 over with a stock stroke. I think if you crunch the numbers that's what it comes out to.
[Re: emarine01]
#907853
01/19/11 05:27 PM
01/19/11 05:27 PM
Guitar Jones
I'm at work and can't get on hardly any sites or I would have crunched the numbers myself, why this site is allowed I don't know.
I think I used the formula in the NHRA rulebook when I figured it. Gasket bore of 4.08 I think. I'll have to check again to be sure.
[Re: Guitar Jones]
#907854
01/19/11 05:31 PM
01/19/11 05:31 PM
Guitar Jones
Maybe it was 10 cc of valve relief, it's been 10 years since I built it so off the top of my head I don't remember exactly.
[Re: emarine01]
#907856
01/19/11 05:41 PM
01/19/11 05:41 PM
Guitar Jones
Are you sure about the small chamber w5s ? If they are like in the 60s range the math works
Yeah I'm sure on that, they were like 55cc uncut and the head porter milled .050 off them to get 47cc.
[Re: emarine01]
#907858
01/19/11 06:25 PM
01/19/11 06:25 PM
Guitar Jones
Well I guess as long as it runs strong all is good PS.. race fuel is your friend
lol, yeah 112 is all I put in it.
