w-5 guys piston talk ! #907840
01/18/11 03:42 AM
01/18/11 03:42 AM
CA.
RAY1969CARS Offline OP
CA.
i want a dome piston for my stoke stroke 360 what brand ???? what did did you use ?? pics ???
Re: w-5 guys piston talk ! [Re: RAY1969CARS] #907841
01/18/11 04:17 AM
01/18/11 04:17 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
stock stroke?
Ross 99628
read the footnotes...
http://www.rosspistons.com/products/index.php#cid=7&acc_id=0&type_id=2&vehicle_id=39
Tony
70 AARCuda Vitamin C
Re: w-5 guys piston talk ! [Re: 70AARcuda] #907842
01/19/11 12:31 AM
01/19/11 12:31 AM
CA.
CA.
yes stock stoke i called ross at lunch they say thay wont work 1 the 99628s but i think with a lil milling they may ??? a custom set is like a 1000 !!! wow! the 99628s at muscle motors are 609.00 ??? what to do ?!
Re: w-5 guys piston talk ! [Re: RAY1969CARS] #907843
01/19/11 12:42 AM
01/19/11 12:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Check with Diamond I had them change the pin height
on my pistons($35) and had them open the intake valve
relief ($8) to fit my 2.08 intakes on my W-5s... so
for a added total of $43 I got what I needed
Re: w-5 guys piston talk ! [Re: MR_P_BODY] #907844
01/19/11 01:21 AM
01/19/11 01:21 AM
Delray beach, Florida
P
Performance Only Offline
P
$8.00 dollars to open the intake valve reliefs on all 8 pistons? so 1.00 dollar a piece?
machine shop owner and engine builder
Re: w-5 guys piston talk ! [Re: Performance Only] #907845
01/19/11 01:39 AM
01/19/11 01:39 AM
CA.
CA.
how mush did you move the pin up ???
Re: w-5 guys piston talk ! [Re: Performance Only] #907846
01/19/11 08:38 AM
01/19/11 08:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That is correct
Re: w-5 guys piston talk ! [Re: RAY1969CARS] #907847
01/19/11 08:41 AM
01/19/11 08:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont have the paper here in the house but its up
into the oil ring land
Re: w-5 guys piston talk ! [Re: MR_P_BODY] #907848
01/19/11 01:26 PM
01/19/11 01:26 PM
sweden
sshemi Offline
sshemi  Offline
sweden
My last stroker sb had NO custom diamond pistons with no extra work for reliefing the valves on my 2.08 w5s
Re: w-5 guys piston talk ! [Re: sshemi] #907849
01/19/11 05:06 PM
01/19/11 05:06 PM
Guitar Jones Offline
My W5's are small chamber heads cut .050 for a 47cc chamber. I used a flat top piston .011 out of the hole with a .038 head gasket, worked out to like 12.7 IIRC. I guess that doesn't really help you but you can get away with as little as .027 piston to head clearance. My engine has beed 7500 many times with no problems.
Re: w-5 guys piston talk ! [Re: Guitar Jones] #907850
01/19/11 05:16 PM
01/19/11 05:16 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A 47cc chamber, .011 outa the hole flat top with a .038 gasket = 12.7 to 1 compression
Re: w-5 guys piston talk ! [Re: emarine01] #907851
01/19/11 05:20 PM
01/19/11 05:20 PM
Yeah, I think there was about 7cc of valve relief, it's .020 over with a stock stroke. I think if you crunch the numbers that's what it comes out to.
Re: w-5 guys piston talk ! [Re: Guitar Jones] #907852
01/19/11 05:24 PM
01/19/11 05:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Try the Kieth Black compression calc with the numbers you posted Not saying it couldnt be done but....
Re: w-5 guys piston talk ! [Re: emarine01] #907853
01/19/11 05:27 PM
01/19/11 05:27 PM
I'm at work and can't get on hardly any sites or I would have crunched the numbers myself, why this site is allowed I don't know.
I think I used the formula in the NHRA rulebook when I figured it. Gasket bore of 4.08 I think. I'll have to check again to be sure.
Re: w-5 guys piston talk ! [Re: Guitar Jones] #907854
01/19/11 05:31 PM
01/19/11 05:31 PM
Maybe it was 10 cc of valve relief, it's been 10 years since I built it so off the top of my head I don't remember exactly.
Re: w-5 guys piston talk ! [Re: Guitar Jones] #907855
01/19/11 05:36 PM
01/19/11 05:36 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Are you sure about the small chamber w5s ? If they are like in the 60s range the math works
Re: w-5 guys piston talk ! [Re: emarine01] #907856
01/19/11 05:41 PM
01/19/11 05:41 PM
Yeah I'm sure on that, they were like 55cc uncut and the head porter milled .050 off them to get 47cc.
Re: w-5 guys piston talk ! [Re: Guitar Jones] #907857
01/19/11 06:21 PM
01/19/11 06:21 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Well I guess as long as it runs strong all is good PS.. race fuel is your friend
Re: w-5 guys piston talk ! [Re: emarine01] #907858
01/19/11 06:25 PM
01/19/11 06:25 PM
lol, yeah 112 is all I put in it.
Re: w-5 guys piston talk ! [Re: sshemi] #907859
01/19/11 07:41 PM
01/19/11 07:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They showed a relief of 2.07 on the pistons I bought
and the guy even say it would be close so for a
couple of bucks I had them opened up
EDIT
it might have been 2.06 to clear a 2.05 valve
