Fastener Help...440 engine
#907695
01/17/11 10:19 PM
01/17/11 10:19 PM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
I am in the middle of a protracted resto(that's a new one eh?) and I go to put my oil pump back on the engine after a several month hiatus and paint job. I looked everywhere and can't find the bolts. Everything(almost!) had been bagged and tagged, I thought. I am looking for the specific dimensions on the bolts I will need to replace them with, OR if someone sells them new (besides RT Specialties who has good stuff but their website is one I don't find intuitive). I think a nice gent named Bill Alpin used to be on here and might know. I may also be looking for a new set of oil pan bolts(yes I HAVE them but they are a bit mangled). Can someone lend a 'bonehead' like me a hand on this, please? Thanks!
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
Re: Fastener Help...440 engine
[Re: 4boxers4]
#907696
01/17/11 10:39 PM
01/17/11 10:39 PM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
Bill Rolick Check out Bill Rolick. He had a bunch of stuff I was missing. I guarantee you will find the old stuff when the new arrives!! BTW are you putting the old pump on or a standard? If you went to a High Volume you will need longer bolts! Hope this helps!! Chuck BTW where are you in Ohio??
[Re: moparrulzzz]
#907697
01/17/11 10:46 PM
01/17/11 10:46 PM
4boxers4
Heart of Ohio
Thanks! For sure that is my luck too!! It's what was on it(the pump) with about 200 miles of use. It's a Milodon high pressure.
[Re: 4boxers4]
#907698
01/17/11 11:40 PM
01/17/11 11:40 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I got my oil pump bolts from Nick at Compu-Flow He just pulled them out a drawer by the assembly table Nice to have a friend with an engine shop 20 minutes from my house Nick is the best!!! Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 05dakota]
#907703
01/19/11 07:12 PM
01/19/11 07:12 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
are these special bolts?
no not really other than use a good grade and the correct length depending on whether you have a hi volume pump or not .
[Re: Commando1]
#907707
01/19/11 11:07 PM
01/19/11 11:07 PM
Posts: 175 Red Lion, PA USA
scamper340
Red Lion, PA USA
Oil pump bolts length will vary with the oil pump being used .
Use the stock bolts on an aftermarket HV and you'll come up short...
Is this also true for a small block?
[Re: scamper340]
#907708
01/20/11 10:03 AM
01/20/11 10:03 AM
Posts: 21,472 It's a dry heat
gtx6970
It's a dry heat
No, small blocks mount differently. The bolts do not go thru the pump like B/RB engines. They just go thru a flange on the base of the pump into the main cap
