Mini Starter question.... #907591
01/17/11 07:52 PM
01/17/11 07:52 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
My mini starter has a bolt directly on top(pic below)of the pinion gear housing (i think that's what you would call it).
With my 904 trans this bolt boss is hitting the block. Are there any mini starters that don't have the bolt here?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Mini Starter question.... [Re: DemonDust] #907592
01/17/11 08:57 PM
01/17/11 08:57 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Are you refering to the wiring adapter?
If so just remove the plastic cover and take it off. Then bolt the wires right to that spot.
Re: Mini Starter question.... [Re: DemonDust] #907593
01/17/11 08:58 PM
01/17/11 08:58 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
They hit most any engines...
Take that adapter and ext off and you should be golden.
Re: Mini Starter question.... [Re: DemonDust] #907594
01/17/11 08:58 PM
01/17/11 08:58 PM
I'd slice it down with s cutoff wheel. its been a problem with alot of mega blocks. you'll be fine. I have been doing it that way for years.
Re: Mini Starter question.... #907595
01/17/11 11:35 PM
01/17/11 11:35 PM
Menomonee Falls
Menomonee Falls
I'm talking about the bolt boss, that is right in line with the big stud on the electrical connection.
I'll try to draw on the pic an repost....
SDG Motorsports
Re: Mini Starter question.... [Re: DemonDust] #907596
01/17/11 11:43 PM
01/17/11 11:43 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
How much interference does it have Jessie? If its not much, can you either grind the head of the bolt down some, or relieve the block or both? If its hitting on the side of the bolt head, maybe replace the bolt with 12 point head bolt?
Brian Dunnigan
Re: Mini Starter question.... [Re: DemonDust] #907597
01/17/11 11:47 PM
01/17/11 11:47 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
1 2 or 3
home of the
Sox and Martin Hemi Duster
Re: Mini Starter question.... [Re: DemonDust] #907598
01/17/11 11:50 PM
01/17/11 11:50 PM
Menomonee Falls
Menomonee Falls
SDG Motorsports
Re: Mini Starter question.... [Re: DemonDust] #907599
01/18/11 12:38 AM
01/18/11 12:38 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Jesse,
Now that I see what you were talking about in the pm and here. knock that boss down as far as you can. Leave some meat on there for the bolt thread strength.
Re: Mini Starter question.... [Re: DemonDust] #907600
01/18/11 12:38 AM
01/18/11 12:38 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I would trim the block
home of the
Re: Mini Starter question.... [Re: HEMIFRED] #907601
01/18/11 01:01 AM
01/18/11 01:01 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
X2
if you don't do the block, when you need to replace the starter at the track your day will be done.
Joe
Without Data, you’re just another guy with an opinion.
Re: Mini Starter question.... [Re: sr4440] #907602
01/18/11 01:10 AM
01/18/11 01:10 AM
Menomonee Falls
Menomonee Falls
I ended up grinding a groove in the block. The little bit that I could grind off the starter wouldn't have been enough. Now i just hope I ground out enough. I guess I'll find out once the trans is in.
I mocked the trans up on a different block I had and made some templates to lay out some marks on the engine in the car. So hopefully it's right on. i ground a little extra for good measure
SDG Motorsports
Re: Mini Starter question.... [Re: DemonDust] #907603
01/18/11 01:30 AM
01/18/11 01:30 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Haven't you got the car together or did the new trans break? Springs coming, you don't have time to waste, the ice won't wait for ya.
Re: Mini Starter question.... [Re: DemonDust] #907604
01/18/11 01:30 AM
01/18/11 01:30 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
????? what block and is there an adapter or mid plate being used ??
home of the
Re: Mini Starter question.... [Re: rowin4] #907605
01/18/11 09:28 AM
01/18/11 09:28 AM
Menomonee Falls
Menomonee Falls
I have 4 more days
Should be plenty of time to finish
SDG Motorsports
Re: Mini Starter question.... [Re: HEMIFRED] #907606
01/18/11 09:34 AM
01/18/11 09:34 AM
Menomonee Falls
Menomonee Falls
R5 block. Yes I have an adapter plate, here is a pic of that mess. I have alot to do in 4 days....
Building the tunnel should be fun...
SDG Motorsports
Re: Mini Starter question.... [Re: DemonDust] #907607
01/20/11 12:37 PM
01/20/11 12:37 PM
ill
dennismopar73 Offline
ill
ran more than a couple of these starters,
on several diff engines, 440 400, and
318 t0 360 never had this issue??
i wouls say if this is youre issue , change the bolt
or cut it down
Re: Mini Starter question.... [Re: DemonDust] #907608
01/20/11 12:39 PM
01/20/11 12:39 PM
ill
ill
i dont see a dash bar there??
or rocker bars either
modifactions to firewall or floor?
must have them
Re: Mini Starter question.... [Re: dennismopar73] #907609
01/20/11 02:27 PM
01/20/11 02:27 PM
Menomonee Falls
Menomonee Falls
must have them
The way understand it, you only need these things if you remove over 50% of the firewall....
SDG Motorsports
Re: Mini Starter question.... [Re: DemonDust] #907610
01/20/11 02:29 PM
01/20/11 02:29 PM
ill
ill
any mods to firewall
and floor,
but if you dont run ihra /nhra
doesnt matter
