valve spring question #907556
01/17/11 06:42 PM
01/17/11 06:42 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
does any know how high a intake and exhaust lift can be with stock valve springs and keepers on a big block.
thanks Gene
Re: valve spring question [Re: 3wracing] #907557
01/17/11 06:44 PM
01/17/11 06:44 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
WHICH VS's ?
Re: valve spring question [Re: dOc …] #907558
01/18/11 07:35 PM
01/18/11 07:35 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
stock 383 springs
Re: valve spring question [Re: 3wracing] #907559
01/18/11 07:57 PM
01/18/11 07:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Only way to know for sure is to check them and make sure to have AT LEAST .060 more travel to coil bind at fully open valve. Same with the guide/seal to retainer clearance.
Re: valve spring question [Re: MoparforLife] #907560
01/18/11 10:02 PM
01/18/11 10:02 PM
scratchnfotraction Offline
show them your pic Don
thats the reason to measure every time in my book..
get the spring for the cam or one thats is real close to the specs listed
Re: valve spring question [Re: scratchnfotraction] #907561
01/18/11 10:10 PM
01/18/11 10:10 PM
Upper Midwest
Upper Midwest
Pics of damage done by coil bind using a 485 lift cam in a 360 with stock springs. Also broke the cylinder wall, heads, cam and crank. BTW this engine had yet to see anything over 3500 RPM's
Re: valve spring question [Re: MoparforLife] #907562
01/18/11 10:39 PM
01/18/11 10:39 PM
show them your pic Don. thats the reason to measure every time in my book..
I'm convinced
