Redoing rear seat back upholstery of Challenger #907041
01/17/11 10:22 AM
01/17/11 10:22 AM
Switzerland, Europe
Swiss_Robert Offline OP
Switzerland, Europe
The partial-resto of my 1970 Challenger hardtop progresses and now I start dealing with seat upholstery. Beginning with rear seat back.
Removing the partially rotted cover I found the upholstery looking not too bad - it's not foam but may be wool or like enwrapped in mull and having a jute backside. I'll use it again, as I also will reuse the additional divider (between feathers and upholstery) out of jute with horizontal wires through it.
But now to my question:
The remaining, metal feather-skeleton has on its top another stripe of jute attached (see pic). It has a wire stitched in on both edges (that's where it has cracked).
What's the duty of that stripe out of jute? What will happen, when it's left away?
Is it appropriate to just use textile cord to knot a rough web instead of that stripe?
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907042
01/17/11 10:46 PM
01/17/11 10:46 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Are you sure that wasn't part of the cover?
I believe that there was a mesh material past the vinyl to stretch onto the frame.
Re: Redoing rear seat back upholstery of Challenger [Re: wally426ci] #907043
01/18/11 06:29 AM
01/18/11 06:29 AM
Switzerland, Europe
Switzerland, Europe
Yes, I'm sure.
It has a wire on each edge which are fixed to the frame using hog rings. And all that stuff has genuine-looking labels attached, so I assume it's all stock.
It was not only under the cover (which has a slime foam-padding there at the top edge) but also under the upholstery (the enwrapped wool material).
I now guess it's there to prevent the upholstery material to sink down behind the feather-frame or kind of supporting it...
...just not to say I'm sure about that. I remember that the upholstery material was not really fixed to the rear seats frame with hog rings but just layed onto that jute-stripe. Makes sense - that wool-stuff and enwrappment is not very robust and would not bear a lot of tension.
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907044
01/18/11 11:00 AM
01/18/11 11:00 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Mine was the same way. I believe it is just support for the foam and cover. I reinstalled it prior to recovering.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Redoing rear seat back upholstery of Challenger [Re: 19cuda73] #907045
01/18/11 11:12 AM
01/18/11 11:12 AM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
another picture
1972 Corvette
Re: Redoing rear seat back upholstery of Challenger [Re: 19cuda73] #907046
01/18/11 11:29 AM
01/18/11 11:29 AM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
Same here...
Until total honesty is on the table, we're not even talking about reality...
Re: Redoing rear seat back upholstery of Challenger [Re: Iceman01] #907047
01/18/11 01:02 PM
01/18/11 01:02 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
It's a support but it's also a framing spacer....You'll need to keep that piece on the frame no matter what material you use to replace it...Burlap is easy to find over here at any upholstery shop if you want the original material...I'd think it's used{for upholstery} where you're at also....
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907048
01/31/11 08:56 AM
01/31/11 08:56 AM
Switzerland, Europe
Switzerland, Europe
It worked - this is just sharing the pics:
Sewed a new stripe out of burlap.
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907049
01/31/11 09:00 AM
01/31/11 09:00 AM
Switzerland, Europe
Switzerland, Europe
Reused the wire-armed burlap mat that lies on the steel feathers. And reused the upholstery material that is like wool. Removed the enwrapping and cleaned as good as possible (vacuum cleander).
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907050
01/31/11 09:05 AM
01/31/11 09:05 AM
Switzerland, Europe
Switzerland, Europe
Enwrapped it newly with new gauze material. Fixed it with rough stitches to the old burlap backside.
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907051
01/31/11 09:07 AM
01/31/11 09:07 AM
Switzerland, Europe
Switzerland, Europe
Fixed this "new" upholstery package to the frame using some hogrings from backside. Looks rough but - will do it.
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907052
01/31/11 09:10 AM
01/31/11 09:10 AM
Switzerland, Europe
Switzerland, Europe
Went on with the new back seatback cover - from Legendary (got it from Dante's). It's impressing good quality - but I missed the wire in the topside seam, so I inserted an electrical wire.
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907053
01/31/11 09:13 AM
01/31/11 09:13 AM
Switzerland, Europe
Switzerland, Europe
There's a lot of tension at the lower edge. Used more than one hogring in some holes...
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907054
01/31/11 09:16 AM
01/31/11 09:16 AM
Switzerland, Europe
Switzerland, Europe
Looks not too bad! Some folding I could not pull out, may be upholstery needed to be filled up a bit - but the seams are where they should be. Took me about 20 minutes to admire it
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907055
02/01/11 11:09 AM
02/01/11 11:09 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
Just a quick tip to get those wrinkles out if you want to go through the trouble. remove all the hog rings and follow the exact directions from legendary. i think that they say to start at the center and work your way out to the edges and that should pull the right tension to get rid of those wrinkles. It worked for me on my rear seats and there were no problems. Nice job either way. Seat Upholstery is no walk in the park and can be annoying at times. Legendary has online instructions off their website.
Re: Redoing rear seat back upholstery of Challenger [Re: 70plymA34] #907056
02/01/11 11:18 AM
02/01/11 11:18 AM
Switzerland, Europe
Switzerland, Europe
Well, I DID follow those directions.
If the seam of the cover is on the edge of the upholstery - it cannot be pulled more sidewards.
I assume I lost a bit volume in the upholstery material.
Usually the rear bench is the easiest piece to start with... will get harder.
Re: Redoing rear seat back upholstery of Challenger [Re: Swiss_Robert] #907057
02/01/11 12:56 PM
02/01/11 12:56 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
I tried to duplicate exactly what was under my seat cover with new material. The best way to possibly fix that problem is to maybe start again. I used 3 or 4 layers of cotton batting cut to the exact dimensions of the original batting then wrapped it in cheesecloth which holds the batting together. Also did you slightly heat the covers to make them more elastic to work with before installation. here is a pic of my rear seat after installation and to legendarys instructions. I noticed with each hog ring placed it would eliminate the wrinkle.
Just some advice to you if you are doing bucket seats. Bring them to a seat shop with a small steam unit. That makes installation a little easier. You are right, the rear seats are easiest, the fronts are a different story. Be patient and I am sure your rear seat will come out fine.
Re: Redoing rear seat back upholstery of Challenger [Re: 70plymA34] #907058
02/01/11 01:17 PM
02/01/11 01:17 PM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
I had the same question to myself about that middle piece. I just left it out and made the foam under it longer,while rolling it over the frame, and turned out great.Sorry didnt take a pic of that just have pics of the bottom and my front seats.
Re: Redoing rear seat back upholstery of Challenger [Re: bee71mopar] #907059
02/01/11 05:11 PM
02/01/11 05:11 PM
Canada
demon Offline
demon  Offline
Canada
Where you hog ringed the cover to the lower frame, the rings should go thru the opposite side of the holes. This will make the cover fit snugger but will help with the wrinkles too.
