Torque Thrust wheels at the track? #907010
01/17/11 08:53 AM
01/17/11 08:53 AM
MN
JERICOGTX Offline OP
MN
Anyone running Torque Thrust wheels at the track? If so what lug nuts are you using? Open end? Any one know if they fit over 5/8 studs for the rear?
Thanks.
69 GTX 68 Road Runner
Re: Torque Thrust wheels at the track? [Re: JERICOGTX] #907011
01/17/11 09:21 AM
01/17/11 09:21 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A few guys were running them.It depends how fast you are going.I run long studs and open ends on my wheels as does my kid.Ive seen lots of mostly stock type cars run standard lugs.I dont believe the 5/8s will fit unless you open the holes.That and you have to drill the axles also to use them.Just make sure you use the proper lug nuts for the wheel.Rocky
Chrysler Firepower
Re: Torque Thrust wheels at the track? [Re: therocks] #907012
01/17/11 11:38 AM
01/17/11 11:38 AM
MN
MN
I already have 5/8 studs in the axles. IF the rears need to be opened up, I'm fine with that, and can have a buddy machine them out.
Does anyone make conical lug nuts that are open on the ends?
Jeff
Re: Torque Thrust wheels at the track? [Re: JERICOGTX] #907013
01/17/11 11:42 AM
01/17/11 11:42 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
yes: stock car boys use them, the 1s i picked up were 5/8x11 thread, might not be what you want. i didn't want them as wheel nuts.
Re: Torque Thrust wheels at the track? [Re: 3ddart] #907014
01/17/11 11:43 AM
01/17/11 11:43 AM
an8sec70cuda Offline
Go to your local roundy round race shop. They should have em.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Torque Thrust wheels at the track? [Re: an8sec70cuda] #907015
01/17/11 04:10 PM
01/17/11 04:10 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
I have a buddy that runs 9.40's with them
Re: Torque Thrust wheels at the track? [Re: Thor500] #907016
01/17/11 05:00 PM
01/17/11 05:00 PM
MN
MN
Does the car have 5/* studs in the axles?
Just curious how he is running them.
Thanks.
Jeff
Re: Torque Thrust wheels at the track? [Re: JERICOGTX] #907017
01/17/11 05:20 PM
01/17/11 05:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
It seems like on my TT, Moser drilled and tapped 5/8" into my axles, but on a 5" BC, and the studs were 5/8" with an 11/16" shank, and they fit pretty snug on the rims, but I don't think a 4.5" BC would work well with the larger studs. Not sure. ( )
Re: Torque Thrust wheels at the track? [Re: JERICOGTX] #907018
01/17/11 05:43 PM
01/17/11 05:43 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
Thanks.
Jeff
Still runs with 1/2"
Re: Torque Thrust wheels at the track? [Re: jcc] #907019
01/17/11 06:23 PM
01/17/11 06:23 PM
MN
MN
Having enough room with 4.5" BC was another concern...
Re: Torque Thrust wheels at the track? [Re: JERICOGTX] #907020
01/18/11 12:37 AM
01/18/11 12:37 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Jeff the 1/2" studs will just fit on a 4.5" BC
I had to go with 3/4 hex on the nuts because because 13/16 sockets were just to large and the socket would gouge the center of the wheel.
I wanted to go with the 5/8" drive studs but you will need to have someone make a spacer with a small enough O.D.so you can fit the large nuts past the rim center.
You almost HAVE go with a 5 on 5 bolt pattern to get a 5/8" stud and nut to work
Gus
64 Plymouth Savoy
Dana 60
Re: Torque Thrust wheels at the track? [Re: fourgearsavoy] #907021
01/18/11 11:42 AM
01/18/11 11:42 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I know a guy that runs them on his Barracuda with 4 1/2" bolt circle with slight mods. I looked into doing it with my American 200S. The nuts and washers would need to be downsized but it looks like it could be done at 4 1/2" cicle. 5" would make it easier though.
Doug
Re: Torque Thrust wheels at the track? [Re: JERICOGTX] #907022
01/20/11 05:33 PM
01/20/11 05:33 PM
N.E. IL. U.S.A.
Rumblefish68 Offline
N.E. IL. U.S.A.
I'm the guy Doug knows with the 5/8" studs on 4 1/2" bolt circle. I'll
post the info. after I measure everything at my shop this weekend.
It is really easy and worked well, But I would change 1 thing if you don't have the wheels yet. I did this to Torque Thrust "D"'s.
Don't know about other models. Excuse my typing, I'm new at this posting stuff.
Re: Torque Thrust wheels at the track? [Re: Rumblefish68] #907023
01/20/11 08:01 PM
01/20/11 08:01 PM
Chicago
curbman68 Offline
curbman68  Offline
Chicago
Maybe with some custom inserts the 5/8" studs will work with the 4.5 BS. I had a guy make me some for my Motor Wheel Flys, he'll do any kind of custom inserts you want. The name of his business is Speed Doctor Racing Components.
Re: Torque Thrust wheels at the track? [Re: Rumblefish68] #907024
01/20/11 09:25 PM
01/20/11 09:25 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Your first post,now you'll be hooked like me.
Doug
Re: Torque Thrust wheels at the track? [Re: JERICOGTX] #907025
01/22/11 03:25 PM
01/22/11 03:25 PM
N.E. IL. U.S.A.
N.E. IL. U.S.A.
Here's what I did to my torque thrust "D" 's on my nostalgia S/S car that runs 9.60's:
Redrilled the holes using a 21/32" bit. Used the existing taper to center the bit.
Used a metric M-16 washer (hardened DIN 125A, which is larger than a standand M-16, O.D. wise)in the recess and used a 5/8 x18 hex nut as a lug.
Reduced the O.D. of a 6 point deep well 15/16" socket to fit the recess lug
hole and torqued to 65 ft. lbs.( ground on a bench grinder, don't need much)
Did this to 2 sets 12 years ago and used to check them all the time.
Now I check them once a weekend. In 12 years, I never had one loosen up.
