Need a little help. 1968 Hemi Dart hood scoop location? #906613
01/16/11 05:34 PM
01/16/11 05:34 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
I'm about ready to mount my scoop on my Hemi Dart and I was wondering where to mount it. I'm looking for the measurement from the back of the scoop to the back of the hood.
Thanks, Troy
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: Troy] #906614
01/16/11 06:13 PM
01/16/11 06:13 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
From the front edge of the COWL to the back edge of the scoop is 3.5 inches (so you can have room to adjust the hood). Remember that your "hole" needs to be and inch or two inside of that for the scoop to be bolted down and more then that in the front so you can run your spars down. I am running a AAR fiberglass hood and you may be cutting into the frame a bit and that needs to be finnished off as well. I had the motor in and then cut as to fit the cross ram.
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: Troy] #906615
01/16/11 06:20 PM
01/16/11 06:20 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
LOTS of guys would ask for them to be as far FORWARD as possible.
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: dOc …] #906616
01/16/11 06:24 PM
01/16/11 06:24 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Where were they placed originally OE from the factory/Hurst?
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: DANA60] #906617
01/16/11 06:24 PM
01/16/11 06:24 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi Tim
I'm I reading you correctly....you say from the "cowl to the back of the hood scoop is 3 1/2" So what kind of air gap do you have between the cowl and the back of the hood?? My car is not here so I can not measure from my cowl forward.
Thanks, Troy
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: DANA60] #906618
01/16/11 06:55 PM
01/16/11 06:55 PM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Mean looking Dart Primetime! Any other pictures for us?
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: Airgrabber] #906619
01/16/11 07:06 PM
01/16/11 07:06 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
...it's coming along....
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: Troy] #906620
01/16/11 07:11 PM
01/16/11 07:11 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
.....traction....none!!
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: Troy] #906621
01/16/11 08:27 PM
01/16/11 08:27 PM
scratchnfotraction Offline
maybe this will help
right off the lot
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: scratchnfotraction] #906622
01/16/11 10:41 PM
01/16/11 10:41 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Sorry I'm late, wathching the F Ball game. About a half inch gap in the cowl-hood, maybe 3/8. I can take more measurements if you want.
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: DANA60] #906623
01/16/11 10:42 PM
01/16/11 10:42 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Another photo
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: autoxcuda] #906624
01/16/11 11:24 PM
01/16/11 11:24 PM
Florida STAYcation
Florida STAYcation
3 to 3.5 sounds about right.
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: dOc …] #906625
01/17/11 11:36 AM
01/17/11 11:36 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
troy: this pic is from the quaker hemi reunion, mcvey's car i'm thinking because of the color. dave
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: Troy] #906626
01/17/11 11:48 AM
01/17/11 11:48 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Troy, a friend of mine owns an original LO23 car with it's original hood If you need I can run down and take any measurement you need this coming weekend. It's only about 5 minutes from my house
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: 3ddart] #906627
01/17/11 12:17 PM
01/17/11 12:17 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
That is what I was looking for!!
Thanks!!
Re: Need a little help. 1968 Hemi Dart hood scoop location? [Re: gtx6970] #906628
01/17/11 12:20 PM
01/17/11 12:20 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi Bill, hope all is well. I think I will be ok...I have several pictures now and I think I will be good. Thank you very much for the offer.
Troy
