Best motor mounts for stroker #906532
01/16/11 03:32 PM
01/16/11 03:32 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Hello. What motor mounts are best for a high torque motor? 69 GTX, 4 speed, 500 inch 440. Engine should make about 600 pounds of torque. Engine needs to be in stock position to fit air grabber. What do you use? Thanks
Re: Best motor mounts for stroker [Re: frank] #906533
01/16/11 04:55 PM
01/16/11 04:55 PM
AndyF Offline
AndyF  Offline
Get the poly ones from Schumacher
Re: Best motor mounts for stroker [Re: AndyF] #906534
01/16/11 09:21 PM
01/16/11 09:21 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I used the Solid steel Moroso ones on the Challenger here in my Avatar. You may get too much vibration out of them on the street but they will not break or fail!
Re: Best motor mounts for stroker [Re: joewhite440] #906535
01/17/11 12:41 AM
01/17/11 12:41 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I run a morroso steel mount on the drivers side with a big 5/8 inch
bolt/thead size bolt through the big hole in the k frame .
i got the bolt at ace hard ware for a couple of bucks .
the bolt is the best way to keep the engine from moving , because it will shift with stock bolt.
just run a stock rubber mount on passinger side and a poly trans mount .
This works great some vibration but not bad i drive the car all summer like this and i dont mind the extra vibration .
your friends will think the car is even more bad a$$ then it is because it make the car feel faster .
my set up is almost the same as yours 493 hemi 4sp 410 gear 69 charger with 70 pistol grip conslole shifter .
Hope this helps Cj
1969 Dodge Charger 1969 Dodge Superbee
Re: Best motor mounts for stroker [Re: frank] #906536
01/17/11 03:21 AM
01/17/11 03:21 AM
Jensen Beach, Florida
pressureangle Offline
http://www.dodgecharger.com/forum/index.php/topic,13216.0.html
I made this mod to my stock rubber mounts for about $20 including the countersink tool.
Why do I torture myself so?
Re: Best motor mounts for stroker [Re: pressureangle] #906537
01/17/11 08:51 AM
01/17/11 08:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65 with 440 4 speed would tear the cheap rubbers in a short while.I used Imperial Services poly mounts.My kid has them in his 62 300 also.His have been in at least 7 years mine 5 years.No problems and not much vibration.Rocky
Chrysler Firepower
Re: Best motor mounts for stroker [Re: therocks] #906538
01/17/11 03:50 PM
01/17/11 03:50 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
Motor Mounts
The dodgecharger.com link was going to the home page so I posted again; let's see if it works. I used the same 2-bolts through the mount. Started with hex bolts and ended up with a countersunk metric bolts and nylocks because I could not find a countersunk grade 8 anywhere, online, hardware stores, fastenal, etc.
I have what's leftover from a box of 25 if anyone wants a pair.
dstryr, since 1986.
Re: Best motor mounts for stroker [Re: cjs69mope] #906539
01/17/11 04:53 PM
01/17/11 04:53 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Hope this helps Cj
I run almost the same setup minus the poly trans Mount. Mine is 70 Charger RT with 512RB and 4spd. Has some vibration but I think it is fine for the street.
I did have solid mounts on both sides but it was too much vibration for summer cruising.
Re: Best motor mounts for stroker [Re: AndyF] #906540
01/17/11 05:00 PM
01/17/11 05:00 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
These feel like solid and you will hear it in the car. Trust me I had them on the car for an hour and took them off. Not sure if this is a race application, if not use the Magnum mounts from Mancini. They are between stock and poly. They have a lock out on them.
Re: Best motor mounts for stroker [Re: Viol8r] #906541
01/17/11 08:14 PM
01/17/11 08:14 PM
Amherst,NY
challengermike Offline
Amherst,NY
I use a solid on the drivers side and stock one on the pass side and trans,no vibration at all.But i would guess if you had a engine that wasnt balanced real well you would feel it.
Re: Best motor mounts for stroker [Re: dstryr] #906542
01/17/11 09:38 PM
01/17/11 09:38 PM
Northern NJ, U.S.
71X-mark Offline
71X-mark  Offline
Northern NJ, U.S.
Another motor mount option similar to your system is available from DynaTech Engineering in Chelsea, AL. They refer to them as "MityMounts". That's what I installed in my car and so far so good.
Re: Best motor mounts for stroker [Re: frank] #906543
01/17/11 09:46 PM
01/17/11 09:46 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I used the Shumacher poly lock's on my hemi challenger & loved em.
Re: Best motor mounts for stroker [Re: challengermike] #906544
01/17/11 09:52 PM
01/17/11 09:52 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
This is my normal response EVERY time this question comes up. It will never break and the stock side doesn't make it have any vibrations. Cheap and easy...
Re: Best motor mounts for stroker [Re: challengermike] #906545
01/17/11 09:58 PM
01/17/11 09:58 PM
Kirkland, Washington
Pacnorthcuda Offline
Polylock on drivers side, Stock on passenger. I too tried the polys on both sides for about an hour. BUZZ city. Replaced the pass with stock and eliminated 90% of the vibration.
Schumacher doesn;t sell them individually (wonder why??? )
If your interested I'll sell you my extra for my cost ($80 shipped to your door.) 440 biscuit style.
PM if interested.
