Torque box pics needed #90627
07/19/08 07:24 AM
07/19/08 07:24 AM
DFW
68RRFlyer Offline OP
DFW
Hey Guys,
One of the last welding items to do on my 68 Road Runner is to install torque boxes (both front and rear). After looking at them, I just can't see paying $300+ for the set when I can probably make them for nothing except my time. Can someone email me some good pictures of those things from different angles? Address is in my profile. Also, please include some measurements too. Width, height, etc. Big pictures would be appreciated so I can see the details. I fabricated the hemi throttle return spring brackets and wire seperators using photos, and I think they came out pretty good. So I figured I'd give these a shot. Thanks guys. I'm getting close to being done with the welding!
Cheers
Re: Torque box pics needed [Re: 68RRFlyer] #90628
07/20/08 01:13 AM
07/20/08 01:13 AM
DFW
DFW
Ask and you shall receive. Thanks for pictures sent guys. I appreciate it!!!! I'll post some shots when I get done making them. Probably won't be until late next month. Here's the seperators and throttle return spring brackets I made for the hemi. Thanks again. What a great site.
Cheers
Re: Torque box pics needed [Re: 68RRFlyer] #90629
07/20/08 01:49 AM
07/20/08 01:49 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Is your car an original Hemi car or a clone? I ask this because hard tops only had rear torque boxes, fronst were a convertible part. Some cars mistakingly recieved fronts but it was a fluke. Sometimes racers add the fronts because they do help up there.
Here are some rears
Re: Torque box pics needed [Re: ScottSmith_Harms] #90630
07/20/08 02:07 AM
07/20/08 02:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
fronts
Re: Torque box pics needed [Re: ScottSmith_Harms] #90631
07/20/08 02:17 AM
07/20/08 02:17 AM
DFW
DFW
Hey Scott,
It's a Coupe (post) and a clone, tribute, fake, whatever is politically correct these days, but going to try to make it as accurate as I can. So I don't need the front ones then? I didn't know that. They all got the rear leaf spring shackle reinforcements right? (those small plates that connect the rear shackle mounts to the frame) Thanks for the pic and the info.
Cheers
Re: Torque box pics needed [Re: 68RRFlyer] #90632
07/20/08 02:39 AM
07/20/08 02:39 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, you don't need the fronts, and yes they got the inner and outer reinforcement plates in the rear torque boxes and the rear leaf spring eye support plates in the rear of the car. Also a pinion snubber plate. If you need the TB plates and snubber plate I carry both (but no longer carry the boxes).
(Snubber plate shown here)
Re: Torque box pics needed [Re: ScottSmith_Harms] #90633
07/20/08 02:43 AM
07/20/08 02:43 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are the leaf spring plates, torque box plates and the snubber plate
Re: Torque box pics needed [Re: ScottSmith_Harms] #90634
07/20/08 02:50 AM
07/20/08 02:50 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, factory reproduction torque boxes are now sold through Resto Rick. Honestly, making your own (nice ones anyway) might be pretty time intensive and what he sells are pretty darn accurate, perfect, no, but a country mile closer to OEM than anything else you'll find on the market. I'd reccomend dropping the cash for them rather than making your own, they really are worth it and they will look correct.
Here's an original still welded to a chunk of car, the first pics I posted are the reproductions Rick sells for comparisons
Re: Torque box pics needed [Re: ScottSmith_Harms] #90635
07/20/08 02:51 AM
07/20/08 02:51 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Torque box pics needed [Re: ScottSmith_Harms] #90636
07/20/08 03:57 AM
07/20/08 03:57 AM
DFW
DFW
Man, thanks a bunch Scott. That helps out greatly. I'll give it a shot first and see how it comes out. I have the metal already laying around and an afternoon's work should yield some results...or some choice words, one of the two. If it doesn't work out, Rick will be the next call. Thanks again!!
Cheers
Re: Torque box pics needed [Re: 68RRFlyer] #90637
07/20/08 09:08 AM
07/20/08 09:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem. BTW, these are far thicker than your average sheet metal, they are stamped steel, and while I forget the gauge off hand it's about 1/16th of an inch thick! Heavy duty stuff for sure.
