Where to mount aftermarket floor shifter - a-body #905440
01/15/11 04:22 PM
01/15/11 04:22 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
As you'll notice from the pics, I've converted my Dart from bench seat to buckets.
I also just purchased a Hurst Promatic-2 shifter for it.
So now my only question is, where do I mount the shifter to make it something like a stock location ?
Seems to be two locations that would work well, first is the rear position, where the tunnel starts to ramp upwards.
The second position is about 6-8" forward of that, where the tunnel starts to flatten out, more on top of the tunnel.
Any ideas ? Could anyone with a stock floor shifted dart take a measurement from somewhere on the dash or floor to where the shifter handle is ?
Here's pics of both possible installation spots. Both would be comfortable enough. Note: the seats are all the way to the rear right now, which is were they will be when I'm driving.
First a pic of the rear position.
Re: Where to mount aftermarket floor shifter - a-body [Re: MileHighDart] #905441
01/15/11 04:23 PM
01/15/11 04:23 PM
Lyons, CO
Lyons, CO
and a pic of the more Forward position.
Re: Where to mount aftermarket floor shifter - a-body [Re: MileHighDart] #905442
01/15/11 04:32 PM
01/15/11 04:32 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Wherever it feels right .
Re: Where to mount aftermarket floor shifter - a-body [Re: MileHighDart] #905443
01/15/11 04:32 PM
01/15/11 04:32 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
Mount it where it's most comfortable for you
Re: Where to mount aftermarket floor shifter - a-body [Re: rjsjea] #905444
01/16/11 10:33 AM
01/16/11 10:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
X3 ... but if you are looking for somewhat stock , are you mounting a console over it because that's the only way they came from the factory , then you want it rear of the round flat on the side of the tunnel ...
But where it's comfortable for you is the best location.
Re: Where to mount aftermarket floor shifter - a-body [Re: JohnRR] #905445
01/16/11 11:33 AM
01/16/11 11:33 AM
scratchnfotraction Offline
not a Dart but same shifter,I had the same thoughts about where a stock 4-speed location would be
I went with what felt good
one suggestion...cut the hole for the cable first,put it thru the rubber groumet installed in the floor,then mark holes for shifter and mount it to foor,then bolt cable to shifter
I was a ruff 1/4" off had to it just a tad for the cable and groumet to fit and bolt to shifter
i like the shifter,it will work good with the CRT-FMVB I have
Re: Where to mount aftermarket floor shifter - a-body [Re: scratchnfotraction] #905446
01/16/11 11:50 AM
01/16/11 11:50 AM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
What shifter is that?
not a Dart but same shifter,I had the same thoughts about where a stock 4-speed locaktion would be
wound up going with what felt good
I use a ruff 1/4 off had to it just a tad for the cable and groumet to fit
i like the shifter,it will work good with the FMVB
Re: Where to mount aftermarket floor shifter - a-body [Re: 71valiant] #905447
01/16/11 12:58 PM
01/16/11 12:58 PM
man,that first cup of had my spelling off
my shifter is the same as th OP shifter
a hurst pro-matic II,mines a little longer handle for a truck,I did test fit my buddys pro-matic II short handle one also,I would use either in the truck,but was buying one so order it for the truck
swaped in a manual truck steer colum also
Re: Where to mount aftermarket floor shifter - a-body [Re: scratchnfotraction] #905448
01/16/11 02:44 PM
01/16/11 02:44 PM
Lyons, CO
Lyons, CO
Heres where I ended up mounting it last night. Went with where it felt best. A couple inches forward of the rearward position I showed at the top of this thread.
So far I just mounted the shifter, but haven't made the hole for the cable.
I'll try it out again this morning and if it still feels right I'll finish the intallation.
