caltracs and stock leaf springs #904931
01/15/11 09:37 AM
01/15/11 09:37 AM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Can caltracs be used with stock springs? Or do some leafs need to be removed? Or do you have to buy the calvert split leaf spring? I'm way behind the curve, just using pinion snubber and stock hp or superstocks in my different 4spd b-bodys. Also Any axle tube twisting trouble with the caltracs?
Re: caltracs and stock leaf springs [Re: 6PACMAC] #904932
01/15/11 11:34 AM
01/15/11 11:34 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Lots of questions if you plan on racing the car u need to go with the mono leafs cal tracs are meant to work with those.
They will not work with SS springs the two will work against each other.
As far as axle twist that depends on you if you race it then you should beef up the spring perches (sp) that should help with the twist
Re: caltracs and stock leaf springs [Re: 6PACMAC] #904933
01/15/11 11:56 AM
01/15/11 11:56 AM
Az
Crizila Offline
Crizila  Offline
Az
They should work fine with your stock leaf springs - and you probably won't have to change the perches. If you do stay with your stock perches, you might want to consider boxing in the open ends for a little more strength. If you go with the their single leaf springs, you will probably have to weld on new perches as the pinion angle will change - over 8 degrees when I did my late B. If so, I suggest you purchase their purches . Also when I did mine, I went with their "standard" height springs ( they make a +1" and - 1" spring ). My car sat 1" higher with their "standard" height spring. Take that with a grain of salt though as there are a lot of variables with that - how beat out your old springs are, car actual weight, etc. I've only been out once since I made the change from a snubber and front section clipped together and so far only saw about a .004 60' change. I was hoping for a tenth. Still gotta play with them a bit though ( preload and tire pressures ) and my car only runs high 11's. I'm sure a faster car would show much more improvement.
Fastest 300
Re: caltracs and stock leaf springs [Re: Crizila] #904934
01/15/11 12:03 PM
01/15/11 12:03 PM
Az
Crizila Offline
Crizila  Offline
Az
Here is a pic of my stock "iso" system with stock spring perches. They only go about 2/3'rds around the axle and are open on the ends.
Fastest 300
Re: caltracs and stock leaf springs [Re: Crizila] #904935
01/15/11 12:05 PM
01/15/11 12:05 PM
Az
Crizila Offline
Crizila  Offline
Az
Calvert perches. They go 180 around the axle and have closed ends.
Fastest 300
Re: caltracs and stock leaf springs [Re: Crizila] #904936
01/15/11 12:41 PM
01/15/11 12:41 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I used stock springs on my Duster...1.40 60ft with a 10.60-70 ET...Worked well for me..I took all the springs apart and put the stronger arches in the right side. I also boxed the perches..
5.53 @ 125 1/8th on the launch control..more left in her!
