Re: rotisserie question.
[Re: moparmojo]
#90489
07/18/08 08:55 PM
07/18/08 08:55 PM
Posts: 1,383 Az
69hemibeep
Az
Mine was a kit from US cartools its setup to come down to the car. I estimated a centerline through the body as to how much weight was in the roof to the floor, left to right is easy. Raise the car unlock the rotisserie and have a couple buddies for safety. Move the car an inch or two if it feels heavy at that point drop it down and adjust.It only took three adjustments and I could turn the car all the way around with a finger.If you add or subtract parts it changes. I use heavy steel saw horses to set the car on for adjustments.
1969 Hemi Roadrunner 2nd owner
