Re: Oliver Rods..
[Re: Cab_Burge]
#904814
01/15/11 11:11 PM
01/15/11 11:11 PM
Posts: 167 mi
dirty magnum
mi
dont post something like that, no way is it true .. tell your buddy to learn how to use a stretch gauge.. oliver is the best steel rod ..
Oliver doesn't(or didn't several years back) recommend using a rod bolt stretch gauge to tighten thier rod bolts, they wanted you to use the torque plus so many degrees method I bought s set of their steel billet rods for a blown street Hemi project, some of the rod bolts where one length and some where another, .003 differences I called them and ask about that and they said no big deal, that happens all the time One of the rod caps wasn't machine correctly for the bearing tang, they did pay to have it overnighted Fed Ex back to them and then fed Ex overnighted it back to me I would have prefered that they caught that mistake at thier faciltity instead of letting it slip through thier quality(or lack of quality control) control My opinon is Carillos are better, Olivers are not the best steel rod, or aluminum rod company out there now or in the past 1 bad rod out of a set of 8 equals 12.5 % failure rate Not acceptable in my book
its foot lbs then torque by yield ... but a good engine builder dosent just rely on that, they measure the bolts and check the stretch ...thats why oliver gives you a stretch spec, and log book is a good idea for freshing up the motor
Re: Oliver Rods..
[Re: old yeller]
#904816
01/16/11 12:52 AM
01/16/11 12:52 AM
Posts: 8,165 Left Coast
BobR
Left Coast
I have never used them,but the people that i know that have used them there rods have windowed a few blocks!...just telling it the way it is!
Another reason to run aluminum rods.
Re: Oliver Rods..
[Re: dirty magnum]
#904817
01/16/11 03:00 AM
01/16/11 03:00 AM
Posts: 43,174 Bend,OR USA
Cab_Burge
Oliver doesn't(or didn't several years back) recommend using a rod bolt stretch gauge to tighten thier rod bolts, they wanted you to use the torque plus so many degrees method I bought s set of their steel billet rods for a blown street Hemi project, some of the rod bolts where one length and some where another, .003 differences I called them and ask about that and they said no big deal, that happens all the time One of the rod caps wasn't machine correctly for the bearing tang, they did pay to have it overnighted Fed Ex back to them and then Fed Ex by overnight back to me for no charges I would have prefered that they caught that mistake at thier faciltity instead of letting it slip through thier quality(or lack of quality control) control My opinon is Carillos are better, Olivers are not the best steel rod, or aluminum rod company out there now or in the past 1 bad rod out of a set of 8 equals 12.5 % failure rate Not acceptable in my book
I did measure the rod bolts, that is how I found that the bolts where .003 differences in length I ended up calling ARP and ask them which method they preffered me to use on thier bolts( Those rods had ARP 2000 bolts)They said to stretch them to .0057 to .0063 That ended up using 63 to 65 ft.lbs on the shorter ones and 75 to 78 Ft. lbs on the longer ones For the price of the rods and that companys reputation I expected all the rod bolts to be out of the same batch, (same lengths, same heat treat batch and so on) wouldn't you I thought I was going to get perfectly machined rods on all surfaces, not one rod cap that wasn't maybe that is why some motors blow up with Oliver rods and some don't
Re: Oliver Rods..
[Re: Hot 340]
#904818
01/16/11 10:37 AM
01/16/11 10:37 AM
Posts: 572 Shelbyville, TN USA
40ford
mopar addict
mopar addict
Shelbyville, TN USA
My experience goes back a few years. Oliver makes a good, moderate priced rod and is fine for a moderate HP SB---up to the 700HP range and 8500RPM. Over that, I would use either Carillo or Lentz. For some reason, I just like the Lentz rod. No real reason, just personal opinion.
In the past 15 years, we have used 2 sets of Olivers, 6 sets of Carillo and two sets of Lentz. We have never, never had a rod failure. Just be careful of used rods----remember, there is a reason they are used.
Re: Oliver Rods..
[Re: Cab_Burge]
#904820
01/17/11 12:34 AM
01/17/11 12:34 AM
Posts: 167 mi
dirty magnum
mi
i agree if they were that bad i would have sent them back , ive never run into a set like that , another good point is there is forged olivers rods and billit olivers forged are alot cheaper$ , i always use the billit they have a wsb bolt witch is semilar to a L-19 or a carr bolt way better quality.
Re: Oliver Rods..
[Re: old yeller]
#904821
01/17/11 08:45 AM
01/17/11 08:45 AM
Posts: 5,875 communist bloc of new jersey
jamesc
very informative, connecting rods that have failed. please list all the manufactures of connecting rods that have never experienced a failure.
Re: Oliver Rods..
[Re: dirty magnum]
#904823
01/17/11 12:58 PM
01/17/11 12:58 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
This is like any part you can buy. But if you compaire say eagle SIRs rep with Olivers, yes both have had issues, but who has them more often. We had Olivers in our 588, it was a HOG, and got ran hard. Good pieces, but every part bought for any racing application is only as good as the machinist, or guy putting the parts together. If there is a part that went through and has issues, and it was cought before assembly then that shows 2 things, 1 SH!T definatly happends and passes buy QC, and 2 The person doing the assembly was great for catching it. Take the 501 small block build for example, top notch rods were custom ordered and they too had a fault. Now is that something that happens all the time, I doubt it, was it bad for their reputation, Well on Moparts for sure, is their company a good company, sure or they wouldnt be in the business. If I was going to build a top notch engine, Id run them. Hell If I was going to build my build over again they would be in there if I could aford them. Im running Childs track masters now, they checked out great when I got them, and litterally nothing was needed machine wise to make them a go in my build. Now on my cheapo 360 I built I used Eagle SIRs before I knew better, and after all the BS to make them a go I would have been money ahead to get a set of H beams, or a set of scat I beams, but I didnt know they were going to need resizing before runing them. I know now, and I always check over anything I install in any engine no matter what the reputation of the part, and how spendy it is. Its just a good habit to get into. Kasey
Re: Oliver Rods..
[Re: Hot 340]
#904824
01/17/11 02:02 PM
01/17/11 02:02 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I have Oliver rods in my hemi and they were perfect right out of the box. Been beating the snot out of em for over 4 years w/ no problems.
Re: Oliver Rods..
[Re: 40ford]
#904825
01/17/11 04:16 PM
01/17/11 04:16 PM
Posts: 791 Bama
Randy..
Bama
Oliver makes a good, moderate priced rod and is fine for a moderate HP SB---up to the 700HP range and 8500RPM. Over that, I would use either Carillo or Lentz. . ......better not let Nelson Racing Engines know about that. they run Oliver steel rods in there Twin Turbo 632 crate motors makeing 2200hp. just sayin.
Re: Oliver Rods..
[Re: Randy..]
#904826
01/17/11 05:07 PM
01/17/11 05:07 PM
Posts: 2,091 Delray beach, Florida
Performance Only
bottom line is that this is still the internet and your going to get all sorts of "opinions" and "thoughts". some from people that know what they're talking about and plenty more from people that not only don't know, but who have no first hand experience with the product. as i said before, we've sold and used Oliver rods for many years now and i've yet to ever have a single issue, for whatever that's worth.
machine shop owner and engine builder
Re: Oliver Rods..
[Re: Performance Only]
#904827
01/17/11 05:20 PM
01/17/11 05:20 PM
Moparnut426
Well Said!!
Kasey
