Prothane K member isolators #904677
01/14/11 08:21 PM
01/14/11 08:21 PM
Utah
fast360 Offline OP
fast360  Offline OP
Utah
So i have been looking at rebuilding the suspension for my 73' Charger and i have had trouble finding anything for replacing the isolators. Are they not called isolators? i know of aluminum ones but i have been looking at urethane to replace the rotted rubber ones on my car now i have found these: Prothane Motion Control 4-101-BL on summit but they call them body mount bushings and i find that odd because chargers don't have body mount bushings. Can someone clarify this for me, is this what i'm looking for?
Re: Prothane K member isolators [Re: fast360] #904678
01/14/11 08:29 PM
01/14/11 08:29 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
I think they are referring to the same thing. Espo sells poly isolators and calls them "body mount kits".
http://www.springsnthings.com/chrysler-suspension-parts
Re: Prothane K member isolators [Re: fast360] #904679
01/14/11 08:35 PM
01/14/11 08:35 PM
IMGTX Offline
IMGTX  Offline
Energy suspension 5.4111 at the bottom of this page.
http://www.suspension.com/moparcar.htm
I have bought from him and he is a good guy. If you ever put strut bushings in it there are two sizes. The late ones are larger and not available in Urethane ASFAIK.
They are called K-Frame, Crossmember and often body mounts because it depends on if the guy who sells them is a Chevy Fork Or Mopar guy.
Re: Prothane K member isolators [Re: IMGTX] #904680
01/14/11 08:45 PM
01/14/11 08:45 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I think you would like the aluminum ones better as they have zero deflection, and will last forever.
Re: Prothane K member isolators [Re: 469runner] #904681
01/14/11 11:21 PM
01/14/11 11:21 PM
Utah
fast360 Offline OP
fast360  Offline OP
Utah
Thanks for the reply, I'm still considering the aluminum pieces who makes them?
Re: Prothane K member isolators [Re: 469runner] #904682
01/14/11 11:47 PM
01/14/11 11:47 PM
IMGTX Offline
IMGTX  Offline
Aluminum do have 0 deflection but my poly's are 10 years old and have over 100K on them and still look like new.
Re: Prothane K member isolators [Re: fast360] #904683
01/15/11 12:52 AM
01/15/11 12:52 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
OK, check them out at www.SolidBushings.com I installed a set on my 1988 Diplomat cruiser and it made a huge difference in how the car felt. Much more solid feeling. I don't know if cornering was ultimately improved but I felt I had more control and more feedback in turns. It seemed the car wandered less too on just straight stretches. I also eliminated the rubber in the rear suspension.
Re: Prothane K member isolators [Re: fast360] #904684
01/15/11 01:00 AM
01/15/11 01:00 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Don't worry about the solid mounts giving the car a harsh ride. I installed a set in my wagon and the harshness was no worse than a '72 - older B-body. Where I noticed a HUGE difference was on bumpy/washboard roads. With the old rubber isolators, my wagon felt loose, and would dart about. With the solid mounts, on all but the worst washboard, the car now feels more solid and holds a line.
If your Charger is a small block, you probably won't feel as drastic a difference as you would in a factory big block car IMHO.
John
Re: Prothane K member isolators [Re: fast360] #904685
01/16/11 06:24 PM
01/16/11 06:24 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I also installed the aluminum ones on my '88 GF ex-police, and notice huge difference in higher speeds handling. Best upgrade I have made so far, by far.
Facts are stubborn things.
