Re: Not a mopar..but cool!!
[Re: FASTFISH420]
#903742
01/14/11 02:46 PM
01/14/11 02:46 PM
Posts: 11 The Mitten
URE
The Mitten
The LSX is a 3.875 Stroke x 4.155 Bore, with an F3R ProCharger. Should make north of 2000 hp. My 8.2 deck 420 is 3.66" stroke x 4.250 bore. I sold that engine and we might be pulling some stroke out for a class thing, kind of a bummer. Oh and thanks for all the compliments. Much appreciated!
[Re: DakFink]
#903746
01/14/11 06:51 PM
01/14/11 06:51 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Ya'll do know that the W9-RP heads and the SB2 are so similar that Chris says he even uses the same Port Program to do both.
I got to look at a Pair of SB2's about a month ago and if I had not known I wouldn't have been able to tell them apart from my W9-RP heads.
I'm looking forward to getting Chris to put my Combo together for me.
thats why they like the mopar intakes! on sb2
[Re: LA360]
#903748
01/15/11 07:19 PM
01/15/11 07:19 PM
URE
The Mitten
I think there has been some confusion, that I hope I haven't caused with the gentleman above that called me.
There are 2 platforms of mopar intakes we use.
There is a Mopar Wedge intake, that we use on SBChevrolet Wedge heads.
There are mopar intakes developed for the p7 heads, that we use on SB2 and symmetrical port SBChevrolet heads.
I don't recall stating that an SB2 port would fit into a W9RP...
That is not the case and if I mis spoke in a conversation I apologize.
A port is simply the result of cross section, shape, lenth, entry angle, valve angle etc... certainly, if the packaging space was available a port 'similar' to an SB2 designed port could be developed for a W8 or W9 head.... in terms of cross section and shape, but the two would not be the same. And it's unlikely a Wedge head could package a similar port to an SB2 just due to pushrod issues...
But, with enough $$ in the block, and heads maybe?? The last question would be WHY.
