Re: Not a mopar..but cool!!
[Re: FASTFISH420]
#903721
01/13/11 05:11 PM
01/13/11 05:11 PM
Guitar Jones
[Re: sdaurity]
#903723
01/13/11 05:32 PM
01/13/11 05:32 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
Ill see if I can have Uratchko chime in alittle about it..
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: poisondart2]
#903728
01/13/11 06:33 PM
01/13/11 06:33 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Usually you either have a water tank in the trunk, or two small radiators on both sides in the front woth a remote pump.
One day I will have something cool here.
[Re: poisondart2]
#903729
01/13/11 06:34 PM
01/13/11 06:34 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Thats cool, but....... where do you put the radiator?
x2 Where
The few cars that I have seen in person with SC's set up like that run smallish ones (like 15" wide) off to the side with a fan....and/or are alcohol.
[Re: mafo]
#903733
01/13/11 09:25 PM
01/13/11 09:25 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I hope that isn t your new motor...
Why not? This is the racing section and that motor is going to make some car haul azz..
[Re: sdaurity]
#903734
01/13/11 09:28 PM
01/13/11 09:28 PM
BobR
Left Coast
thats cool, but im more impressed with his N/A 420 inch 8.200 deck motor
Chris builds some awesome stuff
420" 302 what does it have any room for a piston and rod. The block would be slam full of crank. LOL Never heard of one that big, would also be interested to hear about that.
That's a Chevy motor. Probably a 4.00 in. stroke.
[Re: FASTFISH420]
#903735
01/13/11 09:38 PM
01/13/11 09:38 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I was just looking at his website last night, wish I had the $$$. Is there only 2 bolts holding those valve covers on?
[Re: ProSport]
#903736
01/13/11 09:42 PM
01/13/11 09:42 PM
Posts: 2,046 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Looks like 4 to me.
[Re: BobR]
#903738
01/13/11 10:01 PM
01/13/11 10:01 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
the 420 inch 8.200 deck is Chris's personal motor its a ford and everyone would like to know how he done it but he doesnt give out his secerts !
[Re: FASTFISH420]
#903742
01/14/11 02:46 PM
01/14/11 02:46 PM
Posts: 11 The Mitten
URE
The Mitten
The LSX is a 3.875 Stroke x 4.155 Bore, with an F3R ProCharger. Should make north of 2000 hp. My 8.2 deck 420 is 3.66" stroke x 4.250 bore. I sold that engine and we might be pulling some stroke out for a class thing, kind of a bummer. Oh and thanks for all the compliments. Much appreciated!
[Re: DakFink]
#903746
01/14/11 06:51 PM
01/14/11 06:51 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Ya'll do know that the W9-RP heads and the SB2 are so similar that Chris says he even uses the same Port Program to do both.
I got to look at a Pair of SB2's about a month ago and if I had not known I wouldn't have been able to tell them apart from my W9-RP heads.
I'm looking forward to getting Chris to put my Combo together for me.
thats why they like the mopar intakes! on sb2
[Re: LA360]
#903748
01/15/11 07:19 PM
01/15/11 07:19 PM
URE
The Mitten
I think there has been some confusion, that I hope I haven't caused with the gentleman above that called me.
There are 2 platforms of mopar intakes we use.
There is a Mopar Wedge intake, that we use on SBChevrolet Wedge heads.
There are mopar intakes developed for the p7 heads, that we use on SB2 and symmetrical port SBChevrolet heads.
I don't recall stating that an SB2 port would fit into a W9RP...
That is not the case and if I mis spoke in a conversation I apologize.
A port is simply the result of cross section, shape, lenth, entry angle, valve angle etc... certainly, if the packaging space was available a port 'similar' to an SB2 designed port could be developed for a W8 or W9 head.... in terms of cross section and shape, but the two would not be the same. And it's unlikely a Wedge head could package a similar port to an SB2 just due to pushrod issues...
But, with enough $$ in the block, and heads maybe?? The last question would be WHY.
