Re: reverse flow cooling plates,
[Re: Mopar_Rich]
#903340
01/13/11 02:43 PM
01/13/11 02:43 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I've used the INDY plate, but I like the reverse cooling Meziere pump better. Higher flow, nothing GM and it has handled 1000 HP engines with no problem. Works great!
But be aware that purging any reverse cooling system is difficult. Air get trapped at the back of the heads. I even have drilled small bleed holes in the head, and I installed a NPT plug later.
Forgot about the Meziere pump , that would be the choice. indy plates wereall that was available at the time we used it .
[Re: SG duster]
#903342
01/13/11 08:08 PM
01/13/11 08:08 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
i have two units in an industrial building, 3600 sq ft,,, the guy in the front uit has a laser,,, he made me some plates out of thin steel that look like the water pump gaskets but have round holes like the front of the block,, made the lower hole smaller to try to pressurize system by having a larger inlet that outlet in and out of the block,, i never have any issues with loosing prime when filling the radiator anymore.
once in awhile i use to have to jack the car up as high as it went with the pump on,, or just keep squeezing the rad hoses
[Re: moderncylinder]
#903343
01/13/11 09:30 PM
01/13/11 09:30 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I don't have reverse cooling but I always fill my cooling system with the Airlift 550000, works great everytime and no air pockets.
[Re: rowin4]
#903345
01/13/11 09:57 PM
01/13/11 09:57 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Id say it pulls a vacuum, never had a problem with air pockets, as long as the radiator is above the water level in the block. But I have heard people having trouble though.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#903346
01/13/11 10:52 PM
01/13/11 10:52 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I have the Indy / Mezziere set up and it works great on my 557" 12.5 :1 Hemi . On a hot (84deg) humid( 74%) day it saw the low side of 180 deg. As for the "bubble" , I just jack the car up so the "low " spot is gone. No problem ! Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: AndyF]
#903348
01/14/11 01:58 PM
01/14/11 01:58 PM
Posts: 89 oregon
ramcharger1964
oregon
Do you guys think a reverse flow pump would work for my setup??? Have a Diamondback 496,440-1's, crossram w 800 Eddy's, 12:1 comp, auto trans, pusher HHR fan and alum rad. I cant seem to keep it under 200 deg, and often it sees 210..........
Hell B!tch Racing Co.
[Re: ramcharger1964]
#903349
01/15/11 01:59 AM
01/15/11 01:59 AM
Posts: 43,214 Bend,OR USA
Cab_Burge
210F won't hurt the motor, it does make the owner/builders worry a lot though Are you using straight water or antifreeze mixed with water? Straight water with water wetter does run a little cooler than 20% antifreeze and water, noticeably()SP?) cooler than a 50% water antifreeze mix What pressure cap are you using also?
[Re: Cab_Burge]
#903350
01/17/11 05:27 PM
01/17/11 05:27 PM
Posts: 89 oregon
ramcharger1964
oregon
Thanks Cab. Not sure on the cap temp but I am using water wetter with straight water. At the track or on the street is usually keeps below 200 - but when I drive it home I have to go up a 2 mile gravel road(verrrry slowly) and thats when it get up to 210 and wants to start detonating....
Also - I have heard people say that you should NOT run a shroud with a pusher fan??? Is this true?
