removing crash bars? #903083
01/12/11 08:20 PM
01/12/11 08:20 PM
KY
juicedcuda Offline OP
KY
What is the best way to remove the door crash bars on an e-body? Are they welded in?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: removing crash bars? [Re: juicedcuda] #903084
01/12/11 08:27 PM
01/12/11 08:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a 4" cut off wheel and just get as close as you
can to the edges and just cut the bar itself, I'm
pretty sure they are welded in but it would be right
at the flange(where the door skin is crimped)
Re: removing crash bars? [Re: juicedcuda] #903085
01/12/11 08:39 PM
01/12/11 08:39 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
On my 73 charger I couldnt get them out with out ruining the paint on my door.
1. Drill out spot welds at front and rear of door were door skins pinch over. Should be six to eight per front and rear pinches. This will release crash beam.
2. Cut into 3rds to remove out opening on inside of door. I used my torch because couldn't get a cutting apparatus inside the door.
I took 38lbs (total for both doors out)!
If you need more info ask.
I will say that the hole where I drilled out I never have filled. THough you cant see them from outside they are fairly large 1/2" or so.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: removing crash bars? [Re: MR_P_BODY] #903086
01/12/11 08:40 PM
01/12/11 08:40 PM
Plainfield, Il.
cuda72 Offline
cuda72  Offline
Plainfield, Il.
How much weight savings can be had by cutting these bars out? I know when I was restoring my '72 Cuda that the doors were a lot heavier than I would have thought.
Re: removing crash bars? [Re: cuda72] #903087
01/12/11 08:50 PM
01/12/11 08:50 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
See my above post.
Re: removing crash bars? [Re: kilroy] #903088
01/12/11 10:20 PM
01/12/11 10:20 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I drilled the spotwelds out and then cut the beams in half. They came right out.
Real Men shift for themselves
Re: removing crash bars? [Re: 1DGEMAN] #903089
01/12/11 11:29 PM
01/12/11 11:29 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I also cut mine out after the car was painted and lettered. I drilled out the spot welds and cut the bars in pieces to remove. After the spot welds were drilled, I slid a thin piece of aluminum between the bar and the door skin, to protect the paint and lettering. Some times you will find some spots of adhesive (1" dollops) between the skin and beam, cut these with a thin wire.
Take your time and you will be OK. I found it easier to remove the door to do this. Your door hinges will thank you.
Brian Dunnigan
Re: removing crash bars? [Re: 1DGEMAN] #903090
01/13/11 12:00 AM
01/13/11 12:00 AM
ill
dennismopar73 Offline
ill
Re: removing crash bars? [Re: juicedcuda] #903091
01/13/11 12:13 AM
01/13/11 12:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have to pull them out of my Rampage in the next
few days... I'm waiting to see if I can find another
door first... if not I'll fix this door and pull the bars
