Thank You Stumpy That's what I wanted to hear. My plan is to run the air line that comes into the shop into the condenser with a couple computer fans on the condenser then out to my air drier then to the regulator. I learned on my last couple cars that I can paint good in the summer but in the winter I get a lot of orange peel. The booth temps are the same summer and winter 75-78 degrees the only difference is the temperature of my air. My compressor sits outside so My air is cold in the winter. I will give this a shot and see if it makes a difference.
