6.1 hemi 2008 #902729
01/12/11 01:59 PM
01/12/11 01:59 PM
Canada
shadowauto Offline OP
Canada
My friend has a 2008 hemi 6.1 very low kms and on hard aceleration it smoke a lot what could be the problem this engine only over heathing one the gage whent in the red only a couple minutes He shut it off and 10 minutes after it started right up I think may be intake gasket what You expert think thanks .
Re: 6.1 hemi 2008 [Re: shadowauto] #902730
01/12/11 10:09 PM
01/12/11 10:09 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
You mean you think it is a head gasket, not intake gasket? Overheating with smoke following the incident sounds like possibility of head gasket.
Has he pulled the dipstick and looked for anything other than oil like substance? How much smoke and what color smoke? More info needed really.
Facts are stubborn things.
Re: 6.1 hemi 2008 [Re: shadowauto] #902731
01/13/11 09:48 AM
01/13/11 09:48 AM
NY usa
540challenger Offline
NY usa
It is time to do a leak down test and seem what is going on in there. Heck 2008 is it not under warranty still????
Re: 6.1 hemi 2008 [Re: larrymopar360] #902732
01/13/11 11:13 AM
01/13/11 11:13 AM
Canada
Canada
the oil is nice and clear the smoke is blue and lost of it some one told me that the 5.7 has intake problem and He said may be the 6.1 has the same problem the car is in storage for winter but I am looking for advise I know that a leak test will have to be done this was a crate motor and the warranty is over thanks.
Re: 6.1 hemi 2008 [Re: shadowauto] #902733
01/13/11 02:47 PM
01/13/11 02:47 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Never heard of an intake problem on the 5.7 or 6.1. That's not to say they can't have one, but I don't believe it is a common issue. We have several at the PD I work for, and none has had any motor issues, and they get beat to hell. The highest mileage one now has close to 80K miles. Alot of blue smoke is obviously not normal. As mentioned, leak down test is probably going to be next step. Curious, is it losing oil or coolant?
Re: 6.1 hemi 2008 [Re: larrymopar360] #902734
01/13/11 04:32 PM
01/13/11 04:32 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
The intakes on these are dry,nowhere to suck in any oil,could be head gasket as mentioned.If he's running a "catch can" and has'nt emptied it in a while it will suck oil from there into the intake, ,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: 6.1 hemi 2008 [Re: bigD] #902735
01/13/11 05:03 PM
01/13/11 05:03 PM
Canada
Canada
Hi I never eard of a catch can this engine only have around 1000 miles and not abuse we use recomanded oil (synthrtic )and it been change twice in the last two years thanks for all reply '
Re: 6.1 hemi 2008 [Re: shadowauto] #902736
01/13/11 05:15 PM
01/13/11 05:15 PM
NY usa
NY usa
A catch can is more seen in the "tuner" growd but also alot of guys running boosted engines use them. It is plumbed into your pcv systems and "catches the oil that is running through it." Either way the fact you over heated even for a small amount of time is no good. Any IMO you are going to have top go into the motor to fix it.
Re: 6.1 hemi 2008 [Re: shadowauto] #902737
01/14/11 04:09 PM
01/14/11 04:09 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Try http://www.lxforums.com/ throw a post up over there & see what the LX guys have to say,D
Re: 6.1 hemi 2008 [Re: bigD] #902738
01/14/11 04:18 PM
01/14/11 04:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Study the layout of the engine and you'll notice it's definitely "possible" for oil to be sucked into the intake ports...however it is not a very common problem, the OE seals are very stout pieces, I have even reused them before w/o any problems....but never say never.
There is a pcv passage on the right intake flange and a breather + oil filler flange on the left intake flange. Oil does pass directly through the intake, because there is nowhere else on the motor for breather/oil fill/pcv.
Intake may be cracked into one of the breather/filler/pcv passages. I have never heard of it happening, but that would definitely do it.
Rich H.
Esse Quam Videri
Re: 6.1 hemi 2008 [Re: ZIPPY] #902739
01/14/11 06:22 PM
01/14/11 06:22 PM
Canada
Canada
Look like He will have to do a leak test and go from there Thanks I will post the problem has soon we find out .
Re: 6.1 hemi 2008 [Re: ZIPPY] #902740
01/14/11 06:22 PM
01/14/11 06:22 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
THe 6.1s manifold is cast alum.,so I kinda doubt it would crack(not saying they can't),The 5.7s are plastic and could be more prone to this,but I've never seen or heard of one cracking.The pcv could be stuck/not working correctly allowing oil to be pulled into the intake under hard acceleration . Whatever it is,you need to do a leak down check or a comp. check,D.
